Body control module question
Old Feb 1, 2024 | 07:42 PM
cutecboy's Avatar
cutecboy
Default Body control module question
Hi all,
I recently had to replace the body control module BCM in my 2022 gx460 premium. The problem I was tackling was fixed with swapping out the BCM however the only problem now is the key fob doesn't lock or unlock the doors. Keyless entry doesn't seem to work as well. Meaning when I walk up to the car with key in my pocket it won't automatically unlock when I pull the door handle. Does this require programming ? If so, is there a aftermarket tool i can use ? Any advice would be appreciated!! Hoping I don't have to take the car to lexus for programing the BCM to key fob.
Old Feb 1, 2024 | 07:52 PM
I suspect an aftermarket scan tool capable of this will cost much more than you'd pay a mechanic to do the job. At Lexus not sure they tend to charge a small fortune for this kind of thing. Perhaps Techstream will do what you want but I don't have experience with new models like yours.
I'm quite certain the module must be synced up with the rest of the system.
Old Feb 1, 2024 | 07:55 PM
cutecboy's Avatar
cutecboy
Everything works except the remote is not synced with BCM. Wondering if anyone else's have any thoughts on this? Yes lexus probably will charge an arm and 2 legs so maybe a inde shop with tech stream tool will be best. Was thinking if I can tackle it better of DYI so I'm collecting information.
Old Feb 2, 2024 | 10:52 AM
cutecboy's Avatar
cutecboy
Does anyone have techstrram and live in south Cali? Thanks
Old Feb 2, 2024 | 07:22 PM
DJPsystems's Avatar
DJPsystems
Question
What city are you in?
Old Feb 2, 2024 | 08:46 PM
cutecboy's Avatar
cutecboy
San Dimas...
Old Sep 12, 2024 | 12:12 PM
bushd's Avatar
bushd
3rd Gear
I just switched out my BCM in 2013 GX 460. Did you get the BCM reprogrammed, and did that fix your issue?
Old Sep 20, 2024 | 03:34 AM
ChillPandaDan's Avatar
ChillPandaDan
10th Gear
For 2003 gx470 to program the key there is a sequence of opening and closing doors and inserting key and locking and unlocking the doors that can program new keys, there is also a sequence to delete the code in the system or load a code from the key I believe, maybe look into if that is still a possible way to do it for free on newer model lexus vehicles? For the gx470 there were multiple ways and only one of them worked for me. There is also different sequences for programming the immobilizer chip vs. The remote lock functions. Good luck
tshannoz
RX - 4th Gen (2016-2022)
Dec 7, 2023 06:21 PM
isuras2
Jun 2, 2022 12:11 AM
JDM400
May 4, 2018 05:33 AM
CCTiger
Jul 3, 2010 05:50 PM
