DashBoard Digital Clock
Old Nov 2, 2023 | 08:28 AM
rakibkamal's Avatar
rakibkamal
1st Gear
Default DashBoard Digital Clock
Lexus Model GSU35L-AWAGKV, Year 2006, RX 350 Dashboard Digital Clock suddenly stopped working. Secondly, Voice greeter [when you start the car first time in a day] welcomes me with wrong month and date - we are in November 2nd but the car greets me 15th March! Could you help me understand if I can fix it with any reset or I must take it to a tech guy? Dealer is not an option for me now.
Old Nov 17, 2023 | 04:48 AM
Sullivan's Avatar
Sullivan
9th Gear
For the clock issue, check your owner's manual for any guidance on resetting or calibrating the digital clock. Sometimes, a simple reset can do the trick. Usually, it involves a combination of buttons on the dashboard or steering wheel. If that doesn't work, it might be worth checking the car's fuse box to see if there's a specific fuse for the clock that needs replacing.
As for the voice greeter problem, it sounds like a weird glitch in the system if it's consistently greeting you with the wrong date. Again, consulting your manual for any instructions on resetting the system might be a good first step. You can also try disconnecting the car battery for a few minutes and then reconnecting it. This can sometimes reset the car's electronics and clear up odd issues.
KaiRX350
Apr 20, 2024 11:32 AM
bubba1855
RX - 4th Gen (2016-2022)
Apr 4, 2022 02:12 PM
t18c97
Apr 1, 2022 01:13 PM
RLM
Apr 29, 2020 12:39 PM
Rx13
Mar 24, 2006 07:04 PM
