Tires
Hello folks,
Just wondering which tires folks got with their 2018 LC. My LC has the performance package and was delivered with the Bridgestone s001l vs the Michelin Pilot Super Sports. It seems that test results are showing that the Super Sports are an improvement over the Bridgestones. Which ones did you get? |
Originally Posted by missedapex
(Post 9994643)
Hello folks,
Mine also came with Bridgestone Potenzas. I checked a few online resources (including Tire Rack), and didn't find these Michelins in this size available in the US (yet). I'm OK with the Bridgestone tires because I'm not racing them, and I like the fact that they were designed specifically for the LC (link below). If you look closely you'll see the Lexus "L" design repeated around the tire - where the tread meets the sidewall. I like this cool detail. Unless competitive slalom times are a priority, I think the Bridgestone tires provide the right balance between performance and a luxury ride. For my driving style, I would buy these same exact tires when the time comes to replace them.
http://www.bridgestone.com/corporate...016120901.html |
Originally Posted by Craig B
(Post 9994651)
I also got stuck with the Bridgestone's, I wanted the Michelin's... When they wear out, I will switch to Michelin's.
Lou |
Originally Posted by flowrider
(Post 9994810)
Maybe you think you got stuck, but I do not. I'm running Bridgestone S-04s on my ISF. And I luv them. The construction and tread is very similar to the S001 so I would expect performance to be comparable. The S-04 is an after market only tire while the S001 is an OEM tire built to the same standards.
Lou |
anyone planning to ditch run flats when the originals wear out?
Yup..a run flat tire question
I've had my LC for a month, and got my first nail last Saturday. I was 1/4" away from the dreaded "non-patchable" sidewall, so I was lucky. Is it stupid to carry your own set of spares in the truck (a front and rear)? I got through a few years of my RC F without a puncture, but it had a repair kit. I'm worried about being far away from a dealer, or not being able to repair a puncture, or it being a Sunday/night/holiday. Does anyone do this?
im not seeing how a spare tire can even fit in the already tiny trunk
Lexus roadside assistance or Triple A should be able to fix it. Ive had runflats on a lot of my cars and have actually driven around on it for a day before I could get one repaired or replaced, shouldnt be a problem.
That being said I just had my tire patched up because of a nail also last week. It would have to be a special order if you want the OEM run flats because they were specifically made for the car. |
Originally Posted by walkedu
(Post 10200689)
That being said I just had my tire patched up because of a nail also last week. It would have to be a special order if you want the OEM run flats because they were specifically made for the car. And honestly, I haven't even looked to see if you could put 2 tires in the trunk! |
Originally Posted by RCFun
(Post 10200735)
Before I went to see if I could get it patched I called the dealership and they had 1 in stock for $304, which is better than tirerack that was listing them for $344. I was surprised. Also, There are cheaper RF options or non-RF as spares (about $160).
^^^^The LC50 has 8½" & 9½" wheels front to rear, that's , that's ½" narrower RCF and the GSF. Because of this you can not run 295s. See attachment with manufacturer's recommendations.
Don't know if you're on 20s or 21s, so showing them both. https://cimg7.ibsrv.net/gimg/www.clu...459e29a7fd.png Lou |
Should have clarified it would be on different rims. That being said 295's can be run on a 9.5 inch (just not optimal), had a few friends running them on their cl65's those were in 19's with a custom offset.
I've also considered this after I blew out a front sidewall on a pothole earlier this month. Although the sidewall split, the tire never lost air, so I was able to get home. If you really want a spare in the trunk, a good tire/wheel shop can set you up with a "donut" (cheap skinny wheel and tire) that will work front or back, and will get you where you need to go. You don't need a full-size setup for emergency-only use. You will likely also need a set of lugs too if you go this route, since the OEM lugs probably won't fit on a donut rim.
A more costly alternative is to have a custom forged rim fabricated (and may as well build it to allow for OEM hardware). You can still save some cost be going narrower than the OEM size. A good wheel shop can do this with the proper offset and clearance to work front or back. If you want to go stock, I believe the front wheel/tire setup will fit fine on the back of the LC. I haven't checked whether it actually fits inside the trunk though. Remember - you'll also need to carry around a jack and lug (or socket) wrench too! Although my vehicle didn't come with these, there appears to be cutouts for these tools under the carpet area. Presumably, a Lexus dealer should be able to acquires these tools - to fit inside those cutouts. |
Good point about a generic donut. I didn't even think about the rim, I was more of the mindset to just have the tire and then be able to have any tire shop mount it on the existing rim. The run flat will get me to the shop on a Sunday, it's more about what happens once I'm there. However, the idea of having the donut that could fit the front AND the rear temporarily might be a good compromise.
