Changing Temperature Units
Old 04-15-18, 07:13 PM
guanche2k9
guanche2k9's Avatar
Default Changing Temperature Units
Hi all,
I FINALLY GOT MY LC THIS WEEKEND!!!! YEAH!
So, I was playing around with the infotainment system, as I was trying to change the units of temperature (as I'm originally from Spain and lived in Canada). I found the area in the system where I could do that:
Menu --> Setup --> Unit of Temperature
When I tried to switch over to °C, nothing changed on my outside or inside temperature readings - they stayed in °F. Am I missing something here? I know that when I changed the units of consumption from MPG to KM/L it would show the change on the gauge cluster.
I would appreciate any feedback please, or see if anybody else here has experienced the same issue - otherwise I will have to take it to the dealer.
Thanks!
Old 04-16-18, 03:38 AM
RichKeagy
RichKeagy's Avatar
I looked into this too. Unlike changing from kilometers per hour to miles per hour, this change is difficult, involves new equipment and will cost a lot.
guanche2k9 (04-16-18)
Old 04-16-18, 08:36 AM
BobBass
BobBass's Avatar
Rich is apparently correct. I found this:
"Can you change the temperature to register from Fahrenheit to Celsius?
Cars built for the U.S. will register Fahrenheit on the A/C display. Cars built for other markets will register Celsius on the display. Lexus does not recommend that the A/C display be modified from how the car was built at the factory."
https://lexus2.custhelp.com/app/answ...-to-celsius%3F
Old 04-16-18, 09:36 PM
guanche2k9
guanche2k9's Avatar
Thanks for your input. I'm just curious, if that's the case, then why would Lexus put the option of switching the units of temperature in the setup menu (if it can't be done)?
RichKeagy (04-17-18)
Old 04-17-18, 03:17 AM
LCInfrared
LCInfrared's Avatar
I would ask the dealer, perhaps they can go into the OBD and change it there.
Old 04-17-18, 08:18 AM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
The setting changes the units in the weather app.
SummerRain
09-03-15 09:07 AM
ZMX808
IS F (2008-2014)
11-24-14 09:29 PM
Burlington
03-31-08 11:24 AM
cyboriax
RX - 1st Gen (1999-2003)
11-16-03 06:51 PM
Quick Reply: Changing Temperature Units
