Toms Dry Carbon Fiber Aero installed on LC500
Just installed the Tom's dry carbon fiber rear diffuser for my LC500. It looks excellent and really compliments the Tom's Titan Exhaust kit I have on. I'll be adding the side skirts and front lip soon as well. Photo's will be posted here as the build continues.
SoneFsport (05-17-19)
Your #1 Lexus Vendor
Glad you got the kit. Amazing build quality.. Congrats!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Zeitaku (05-14-18)
Interesting. Do you have a pic from the back, straight-on? (Not "from the side angle"?) What does it look like with one exhaust slightly lower than the other?
Also, Is there any change in exhaust note w/ that setup?
The Tom's Titan exhaust kit is straight through no baffles. The electronic wires that ran the stock OEM baffles on the stock exhaust were disconnected, zip tied underneath. No CEL and no issues. Runs like a champ sounds amazing. This will not effect your driving mode parameters for the transmission, AFR etc. Even at idle it is still rather quite as the OEM mid pipe has 2 CAT's and 1 resonator per side.
Zeitaku (04-09-18)
Thanks for the response, that's a BIG surprise to me as many cars would trigger a code when disconnected. I'm going to try it on mine with the OEM exhaust, keeping the baffles fully opened all the time. I had done the same with my AM Vantage V8 by removing the fuse #22. It sounded MUCH better with the flaps fully opened permanently.
I think removing the fuse for the exhaust would trigger a CEL for sure. The Tom's exhaust is mounted after the mid pipe. The last set of 02 sensors are at the front of the mid pipe, so this is probably why it does not trigger a CEL for the 02's. However, the diameter of the Tom's is .25 wider in diameter than OEM and it eliminates the excessive pipe bends and the massive muffler in design. The OEM weighs about 25 lb. more than the Tom's exhaust too. The exhaust note from the Tom's has a deep and rich tone Vs OEM.
Unlike the Aston Martin I previously owned, the LC's exhaust baffles are triggered by two seperate circuits so no single fuse can disable them (I have the LC's full electrical diagrams and studied them to confirm). My intention is to simply disconnect the connectors to the baffle motors to achieve the same result. Since you mentioned that action wouldn't trigger the CEL, I'll be achieving the desired results just the same.
Since shutting off the LC resets the trans ECU and the ECU modes all to either Eco or Normal upon starting the car back up, you will have to leave the car running and set your driving mode to Sport+ S and disconnect while it's running I'm assuming. Otherwise, if you shut the car off and disconnect it may leave the baffles in normal mode.
