Where are the speaker upgrades?
Old Aug 24, 2022 | 04:15 PM
355F1's Avatar
355F1
Originally Posted by MLMLC52K18
It's ok that you are getting old.... I only remember because it was the most extensive overhaul of the ML system that I've seen posted on this forum.
Ohhhh I do remember the post now!
Old Aug 24, 2022 | 05:04 PM
NAZTY97's Avatar
NAZTY97
Originally Posted by 355F1
Pics or it didn’t happen!
Old Aug 24, 2022 | 06:22 PM
we are not worthy
i'd love to hear that system.
Old Aug 29, 2022 | 06:09 PM
NAZTY97's Avatar
NAZTY97
I'm actually quite impressed with it.... my only thoughts ( afterthoughts ) are, I probably should have done the same as the GX460 and did two separate amps vs one, the GX460 amps don't ever get hot - as both are mounted under the floor. I may eventually do that, but prior to that, I am having a fan put underneath to blow the hot air out. We put a custom vent into the floor, but it probably needs a little help.
Old Aug 31, 2022 | 04:44 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Talking
That’s an awesome setup. I thought I had seen a few pics in another thread. That shop did a really good job.
Old Sep 1, 2022 | 06:44 PM
NAZTY97's Avatar
NAZTY97
I design my systems, they install them. They've done my 2006 GS300, 1999 RX300, 2014 GX460 and 2015 RC350 prior to the LC. I own an AV company, but used to do car audio decades ago, so I'm not their usual / common client. My projects have been their more "custom" hidden, more higher end installs than the typical factory head unit, add an amp and sub in trunk scenario.
Old Sep 1, 2022 | 09:03 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Talking
That’s awesome! That explains the detail that went into your system. Did they have any trouble taking the interior apart? I’ve only seen an LC taken apart once at the dealership I worked at and it looked like a time consuming job, especially since they were so new at the time.
Old Sep 2, 2022 | 08:31 AM
LEXU5's Avatar
LEXU5
awesome, what shop is this? and whats your AV company? I'm in houston too might have to hit you up for some custom work.
Old Sep 2, 2022 | 04:43 PM
NAZTY97's Avatar
NAZTY97
my company is Superior Audio Solutions
www.superioraudiosolutions.com
I do residential & commercial projects.
the shop that does my cars is American Audio Concepts on Synott & Bellaire. Ask for Gustabo.
Old Sep 2, 2022 | 04:45 PM
NAZTY97's Avatar
NAZTY97
taking the interior apart was a task…. Lots of panels, I don’t know how they keep up with it,… but they got it apart and properly put back together
Old Sep 2, 2022 | 06:54 PM
355F1's Avatar
355F1
I wanted to do a sub of some kind in my LC but it was gonna have to be in the passenger floorboard in a custom-built enclosure.
I love home audio/theater, though! Just got a Lyngdorf MP-40 a couple months ago. This thing is magic!!!!!
I used to be in the car audio and home theater biz back in the 90s-2000s.
Actually....besides my job I have now that was the only other type of job I have ever had!
Old Sep 6, 2022 | 09:37 PM
RaptureEnd's Avatar
RaptureEnd
How much did this setup run you and how long did the install take?
Old Sep 16, 2022 | 06:50 AM
NAZTY97's Avatar
NAZTY97
all in, I think I was just around $9000, which obviously, it could have been done for less, or even more,... I think it was best value for the type of install and sound equipment I wanted, and it took about a week to complete,.... and obviously, being a "First" there were tweaks that had to happen with the install. For example, the amp being under the floor generated enough heat to cause distortion after long periods of use, so we custom cut a hole into floor and fabricated a heat vent to keep stuff from going into the hole, keep equipment invisible, while letting heat out. I have to take it back ( my fault due to scheduling ) to have the stand alone fan put in above to the amp to suck and blow the heat upward and out of that space. We also had to put some foam between rear ceiling liner and the roof, due to a minor rattle. I had to remove bass *** in front, because the clearance between knee and **** on entry was a problem due to size of cabin vs my GX460.
I'll post a few more pics of the system the way it is now vs then in a few ( gotta move car outside to do )
Old Apr 20, 2023 | 05:05 PM
jameshtx's Avatar
jameshtx
I've completely revamped the entire sound system.
I have JL Audio TWik 88 processor, JL Audio FiX 82 DSP, JL Audio HD900/5 amplifier, Focal PS 165 v1 front components, Focal PC 100 4" coax rear side panels, Focal TWU1.5 tweeters ( rear dash ), and two JL Audio 10W3's with custom fiberglass enclosures. We removed factory sub, to allow venting into vehicle from trunk, and also lined the doors with SoundSkins sound deadening material. I am in love with the sound now, but absolutely hated it before.
Dang.....I'm curious to hear how good it sounds
41engine
GX - 1st Gen (2003-2009)
Jul 31, 2020 04:58 PM
RichKeagy
May 22, 2018 06:37 PM
5envolio
RX - 4th Gen (2016-2022)
12
Apr 27, 2018 11:23 PM
a1rh3adsz
Nov 10, 2017 12:44 PM
jkjerob
May 31, 2011 05:03 PM
