bugs, quirks, and usability issues
Old May 18, 2021 | 09:18 PM
Another one... maybe you guys can help with
is there really no way to set the 'home' destination for nav other than typing in an address with the foul on screen keyboard and trackpad?
Home is already a 'previous' destination (i set via voice) but i don't see how to use a prior destination as setting for 'home'?
Old May 18, 2021 | 09:23 PM
Exhilr8n's Avatar
Exhilr8n
Originally Posted by redhot47fl
From one of the newest proud owners (exactly one week):
- The "meter" screen - the one in the center of the driver display, right below the speedometer - defaults to fuel efficiency each time you start the car. Many other informational displays are available if you find and work the menu, but your setting won't hold. The car will default to fuel efficiency each time you start it.
- Windows in the 'vert don't close automatically when the roof comes back up. They do on some other high-end 'verts, but here one has to lift the button assigned to those windows. (First World issue for sure, much like many of these others.)
Seems like I ran across a setting to turn that screen memory on and off. Mine is “stuck” in gear selector. Going to look into it tomorrow.
Is a bit surprising the windows don’t automatically go up when the top is raised. But nice to have the switch to raise them all at once there with the up/down switch. That whole door over the switches is quite nice in design and quality. Love how it is damped as it opens.
Old May 18, 2021 | 09:29 PM
Exhilr8n's Avatar
Exhilr8n
Question. Why does anyone use the onboard Nav instead of Waze or the other popular Nav apps like Google maps?
Old May 18, 2021 | 10:27 PM
for one thing waze on android auto doesn't use the full width screen but i do use both/all.
Old May 19, 2021 | 04:43 AM
redhot47fl's Avatar
redhot47fl
@Exhilr8n: If you find that, please let me know. Apparently, you and others have had some success in locking in a different meter screen than I'm stuck on. Thanks!
Old May 19, 2021 | 09:43 AM
AirForce8's Avatar
AirForce8
Sorry I haven't kept up on this thread I broke a tooth on a jolly rancher and had to have it extracted and prepped for an implant. Not fun man. I'll try and contribute more when I'm feeling better.
Don't forget there are more settings when you move the tachometer to the right. Makes things even more confusing when looking for a setting or option. While skimming I saw mention of the gear position view. I believe changing that view setting is in there.
I did find another quirk. I was on my way home from the tooth bone graft procedure and went to adjust the brightness of the tach area and I somehow pressed the fuel door button and I'll be damned if it didn't open while I was moving. You'd think Lexus would disable that while in motion. I was probably only going 15 or 20 miles an hour so maybe is disables at a higher speed.... I didn't test it. I had to get out at the intersection and close it though.
Old May 19, 2021 | 09:55 AM
DRGibbons's Avatar
DRGibbons
Originally Posted by AirForce8
I did find another quirk. I somehow pressed the fuel door button and I'll be damned if it didn't open while I was moving.
Come on man! That's not a quirk. The LC has been programmed that way to allow for in flight refueling.
Old May 19, 2021 | 10:07 AM
AirForce8's Avatar
AirForce8
That made me laugh and it hurt, thx Doc! 😭😁
Old May 19, 2021 | 11:39 AM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
You lose turn by turn on the hud.
Which reminded me of another annoyance, the hud was always slightly crooked, even at maximum angle adjustment. Dealer Couldn’t even get it level.
Old May 19, 2021 | 01:10 PM
redhot47fl's Avatar
redhot47fl
Talking
Mine suddenly began locking on other screens today. I am unaware of anything I did to achieve this, other than whining here.
Old May 19, 2021 | 01:22 PM
Exhilr8n's Avatar
Exhilr8n
This can deff be adjusted through the settings by the rev counter. The four arrows move it up and down, and tilt cw or ccw
EDIT: thinking back, I never could get the HUD to stay straight on the 2019 coupe. It’s aligning ok so far on the verti
Old May 19, 2021 | 01:37 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
but NOT enough. Like I said, dealer couldn’t adjust it even, without removing the dash. I didn’t like the car that much anyways after 3+ years. Easier to dispose of it.
Old May 19, 2021 | 05:43 PM
Exhilr8n's Avatar
Exhilr8n
Did you replace it with anything similar? Or go a different direction? Or just thin the herd?
Old May 19, 2021 | 06:55 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
With a Urus.
Old May 19, 2021 | 07:42 PM
Exhilr8n's Avatar
Exhilr8n
With a Urus.
Yeah, why mess around modding a car when you can just get a whole new experience? You did stick with the LC three years though. Right now I’m in the honeymoon again and want to be together forever. Going in for full PPF next week. We’ll see how long the romance lasts. But seems like I have covered the bases of various directions. This second LC seems very much the right car for me. Perfect convertible weather right now.
