Mark Levinson audio
Subscribe
Apr 19, 2025 | 09:35 AM
  #571
Does any one know what frequency, Lows, Mids, are projected by the lower forward speakers on the doors? Has anyone opened one up to get at it, is it involved?
I'm hoping its a simple wire thats disconnected.
Reply 0
Apr 19, 2025 | 09:40 AM
  #572
Quote: Does any one know what frequency, Lows, Mids, are projected by the lower forward speakers on the doors? Has anyone opened one up to get at it, is it involved?
They are listed as woofers; https://us.marklevinson.com/in-lexus.html#lc
Reply 0
Apr 19, 2025 | 09:58 AM
  #573
Much appreciated 2959!
Reply 0
Apr 19, 2025 | 10:08 AM
  #574
Quote: Much appreciated 2959!
No problem. They are probably rated in the range of 40-500Hz, I believe average is 20-200Hz for standard woofers. Hope it's something simple for you to fix.
Reply 0
Apr 19, 2025 | 10:14 AM
  #575
The sub in the rear is probably rated towards the lower end.
Reply 1
Apr 24, 2025 | 11:59 AM
  #576
Well I ended up spending hours last night cutting out the plastic grating from the sub speaker cover. A lot more time consuming then I thought it would be. Unfortunately, it didn't completely eliminate the bass rattling. Apparently, it worked for many other members, so now I'm trying to locate the exact source of my rattling. If any coupe owners are looking into doing this mod and don't feel like going through the hours of meticulously cutting out all of that plastic, while ensuring you don't poke any holes in the fabric and would like to trade speaker grilles let me know. It was a real pain in the ***. The round section with the fabric on the opposite side easily detaches from the leather covered body panel once you remove those 12 screws, so the piece isn't that large. Maybe it will work for you since my rattle must be elsewhere.
This pic is before I cut out all of the plastic. I did it perfect though.
Reply 0
Apr 24, 2025 | 04:02 PM
  #577
Quote: Well I ended up spending hours last night cutting out the plastic grating from the sub speaker cover. A lot more time consuming then I thought it would be. Unfortunately, it didn't completely eliminate the bass rattling. Apparently, it worked for many other members, so now I'm trying to locate the exact source of my rattling. If any coupe owners are looking into doing this mod and don't feel like going through the hours of meticulously cutting out all of that plastic, while ensuring you don't poke any holes in the fabric and would like to trade speaker grilles let me know. It was a real pain in the ***. The round section with the fabric on the opposite side easily detaches from the leather covered body panel once you remove those 12 screws, so the piece isn't that large. Maybe it will work for you since my rattle must be elsewhere.
It might also be the upper (3rd) brake light that's rattling. I have that now. Here's a good vid if you want to remove/check it.
Reply 1
Apr 25, 2025 | 08:59 AM
  #578
Quote: It might also be the upper (3rd) brake light that's rattling.
I'll look into that next. In the meantime, if anybody wants to trade subwoofer speaker grilles let me know and I'll ship my pre-cut one over to you.
Reply 0
Apr 25, 2025 | 01:23 PM
  #579
LC Repairs & Maintenance
I think we should have a sticky thread for repair and maintenance related videos - oil change, transmission oil change, diff oil change, brake jobs, light replacement, etc. It would be more useful for DIYers to get to these very quickly instead of searching among threads.
Reply 1
May 4, 2025 | 03:24 PM
  #580
Thought of buying a new brake light to get rid of the rattle...but, I do love a good Sunday project. Almost as much as I like saving myself some coins.
Once removed, if you tap on the brake light assy., you can hear all kinds of rattling. The light bar inside is just not properly secured. The unit is sealed but I decided I needed to get inside so I got a little story.
Wanna here it...here it go!
https://lexus.oempartsonline.com/oem...amp-8157011010
High Mount Lamp Assembly
Reply 3
May 4, 2025 | 04:33 PM
  #581
Nice work and write-up! I like saving coin too so if/when I incur this issue your endeavor will be helpful. Thanks
Reply 0
May 4, 2025 | 04:44 PM
  #582
Quote: Nice work and write-up! I like saving coin too so if/when I incur this issue your endeavor will be helpful. Thanks
You're very welcome! Hope you never need it, but if you do...
Reply 0
May 5, 2025 | 07:38 AM
  #583
Quote: You're very welcome! Hope you never need it, but if you do...
Bookmarked just in case this problem presents itself in mine! Great write up and crafty problem solving, thanks!!
Reply 0
May 5, 2025 | 08:26 AM
  #584
Quote: Bookmarked just in case this problem presents itself in mine! Great write up and crafty problem solving, thanks!!
you're welcome & thanks, bro...any time.
Reply 0
May 5, 2025 | 08:33 AM
  #585
Quote: you're welcome & thanks, bro...any time.
Quote: I think we should have a sticky thread for repair and maintenance related videos - oil change, transmission oil change, diff oil change, brake jobs, light replacement, etc. It would be more useful for DIYers to get to these very quickly instead of searching among threads.
This was suggested and sounds like a good idea but haven't seen a response. Can it be done?
Reply 0
