Dashcam wiring to trunk?
Plan on hardwiring my dashcam and, as the battery and fusebox are in the trunk, need to figure out how to get the wire into the trunk from the interior. Anyone find an easy way to fish the wire through?
Uh.... Fusebox is located in the driver seat and passenger seat... What dashcam are you going wotw?
I installed the blackvue 900 4k with the 124 battery. I have a short daily commute and would like to charge the battery faster, reason I'm looking to hardwire vs cig lighter charge
You sure? I'm aware of the one under the hood and one in the trunk. Where are the fuseboxes located by the passenger seat?
Yup I hardwired the dr900 to a PMP. I wired it on the driver side. It's underneath the steering column, in the back. Passenger side you have to remove the plastic cover/trim under the glove box. Your manual should indicate how to take it odd
glad I asked, I'll take a look at the manual tonight. any issues using the pmp for parking mode? I purchased the battery as I was concerned about the drain on the battery.
Havent had much issues yet? I only use it when I park in public places, I think a lot of cars are deterred when they see blinking light. I just need to figure out if there is a setting that indicates a video clip has collision detected in the sebsor or something
I agree, when I get back into my car, I have like 100 new video clips. Wish there was a way to filter out more specific events.
Thanks for the tip arc. I found the fuse box on the passemger's side. For the blackvue 124 hardwiring, I need a fuse greater than 20A that's an accessory fuse (vs constant).
I attached a pic of the passenger side fusebox.
Only possibilities seems the top 3 which are 30A each labeled S/HTR P, DOOR P NO1, DOOR R/R 1. Anybidea which one of these fuses are accessory and not constant?
Am lurking on this LC thread as researching how ot wire a dash cam for a 2004 RX 330. Do you mean the FUEL OPN fuse for the fuel door? Also for my car the FUEL OPN is the only relatively uncomplicated (doesnt tie into suspension, air bags etc.). The problem is the manaual says it opens the fuel door and depressurizes the gas tank. Know anything about the despresurization part?
