ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   LC Model (2018-present) (https://www.clublexus.com/forums/lc-model-2018-present-290/)
-   -   Q's on purchasing a non-Lexus-certified LC (https://www.clublexus.com/forums/lc-model-2018-present/1032015-qs-on-purchasing-a-non-lexus-certified-lc.html)
sixfootewok Nov 19, 2024 01:01 AM
I've never bought a used car that a warranty would be any good for, but the LC seems to be something to consider one for. If I didn't find a Lexus Certified LC, what is the best route for third party warranties? Is there anything Lexus would sell you?
Second question, assuming I DID find a certified, how does that work wrt service? Can it be brought to any Lexus dealership or do they pin you to one?
Thanks all!
2959 Nov 19, 2024 05:28 AM
Every used Lexus vehicle I've purchased has been Lexus Certified, specifically for the added Warranty, maintenance and inspections. Case in point, the RX we just purchased was the dealers Loaner vehicle with 13K miles. Since it was LC, we get 61 months of Warranty, 4 free maintenance visits and all the benefits of a new vehicle (like free Loaners). Some Connected Services may not be included due to time like XM.
https://www.lexus.com/lcertified/certification-warranty
np20412 Nov 19, 2024 11:19 AM
L-Certified warranty is backed by LExus, operates the same as and is just an extension of the basic factory warranty. It is required to be honored by any Lexus dealer, not just the selling dealership.
Highline-Autos.com Nov 19, 2024 11:31 AM
Hey @sixfootewok , we are a retailer of Fidelity Platinum extended warranty coverage, repairs accepted at all Lexus dealerships and licensed independents in the US/Canada. Follow the link below for coverage lengths, deductible options, and an example contract that explains coverage. Talk to you soon.
https://mailchi.mp/highline-autos.com/extended-warranty
Highline Autos
Direct: 844.999.0588
Office: 480.348.0777
IcyBishop Nov 19, 2024 03:39 PM
Lexus will not sell you anything additional, but then again if you're buying a LC from a dealer chances would be good it's already certified.
The 3rd party warranties would be options if you get it from any other dealer and are basically forms of robbery, so do heavy research and read the fine print at least 10x before purchasing one. The fine print not only identifies what they cover, but (should) identify how a claim will not be covered. That should all be understood and factored in to how you plan on using the car.
Also be aware that you do have choices for 3rd party warranties, you are not tied to the dealer's options (which are always overpriced so they can get their cut).
If a warranty is super important to you - be patient and find a LCert. It will be cost effective, less hassle in the event something major does happen, and in most cases much better coverage.
BruceinFla Nov 20, 2024 05:23 AM
Don't believe ANYONE why tells you their POS 3rd party Wi****WasALexusWarranty is Just As Good as a factory warranty. It isn't. If it Was As Good As A Lexus Warranty IT'D BE a Lexus warranty.
If it was as good as a Lexus warranty their BBB score would be better than some 3.4 or similar DISsatisfaction rating. Some will lie right to your face and say Oh No we've got No complaints when there's hundreds of them on their BBB page. Do Your Homework.
The 3rd party clown who is flipping the black glass magic 8 ball to determine if their wannabe a warranty is gonna pay for your repair is Hundreds maybe Thousands of miles from You or Your car.
Just how fair To You then do you think that determination will be?
You warranty needs to come from Lexus Financial. Period.
Bruce in Fl
Highline-Autos.com Nov 20, 2024 07:51 AM
As I told @CaryCatch , "I'd highly engourenge consulting with a service advisor on Fidelity Platinum coverage, I'm sure you will hear nothing but good things.... just make sure it is a service advisor, and not the F&I sales office at the dealership."
Here are the exclusions for both coverages, and both can be used at the Lexus dealership service center.
Lexus LSA Exclusions:
Accessory Drive Belts; Batteries; Body Panels; Brake Linings, Pads and Shoes, Rotors and Drums; Bumpers; Carpet; Chrome; Clutch Friction Disc and Pressure Plate; Dash Cover and Pad; Door Fabric; Door Trim; Filters; Fluids; Fuel Cell Air Compressor; Fuel Cell Boost Converter; Fuel Cell Electronic Control Unit; Fuel Cell Hydrogen Tanks; Fuel Cell Power Control Unit; Fuel Cell Stack; Fuel Cell Vehicle Battery Pack; Glass (including Windshields); Hybrid Vehicle Battery Pack; Hybrid Vehicle Battery Plug Assembly; Hybrid Vehicle Relay Assembly; Hybrid Vehicle Supply Battery Assembly; Hydrogen Fueling Electronic Control Unit; Interior and Exterior Trim and Moldings (including but not limited to: Ashtrays, Covers, Cup Holders and Vents); Lamps, Light Assemblies/Housings and Light Bulbs; Nuts, Bolts, Clips, Retainers and Fasteners; Paint; Rust and Corrosion Damage; Seat Covers; Sheet Metals; Shiny Metals; Spark Plugs; Structural Framework and Welds; Tires; Vacuum Hoses, Lines and Tubes; Weather Stripping; Wheels and Rims; Windshield Wiper Blades (Rubber component); All interior and exterior cloth, leather and stitching including convertible tops and/or vinyl tops including but not limited to: any vibration, deterioration, discoloration, disfigurement, warping, fading, staining, Headliner; Heating Hoses, Lines and Tubes; Hoses; stretching, ripping, punctures, tearing and/or scratches.
Fidelity Platinum Exclusions:
Brake linings, brake drums and rotors, disc brake pads, standard manual transmission clutch friction disc, pressure plate, pilot bearing, throw-out bearing and arm, air bags, solar powered devices, glass, lenses, sealed beams, body parts and/or panels, weather stripping, trim, moldings, lock cylinders, tires, wheels, all batteries except hybrid/ev/hydrogen high voltage batteries as listed under gold, light bulbs, upholstery, paint, bright metal, freeze plugs, filters, heater and radiator hoses, exhaust system, catalytic converter, work such as front-end alignment or wheel balancing (except when required in conjunction with a mechanical breakdown), safety restraint systems, audio/security or other systems not factory installed.
Highline Autos
