Winterization Question
Old Nov 5, 2024 | 04:14 PM
gdurhamski's Avatar
gdurhamski
Originally Posted by tofuprod
50?! I mean I think OEM tires rate it max at 50 but I dont think I would go past 40(ish).
However, I'm sure others may have done it that high, I just feel like that's a bit close to comfort for me, even with the climate being colder here in Chicago.
Yep 50 psi. Been doing this for almost 20 years on all my Porsches and BMWs. When you get ready to drive them in the spring, the PSI is usually dropped to around 46 to 47 psi. I have never had a flat spot or any problem.
Old Nov 5, 2024 | 04:25 PM
tofuprod's Avatar
tofuprod
Ah makes sense. I usually drive mine at around 34-36 PSI so that's all relative.
Old Nov 5, 2024 | 04:57 PM
Oro's Avatar
Oro
I do all the above things mentioned including removing Collison insurance on the car as it will not be driven, and I also suspended my Satellite radio subscription for several months. You can easily do this with 2 quick phone calls. I increase the tire pressure to 50 psi on all my cars that I store.
That’s sounds like a good idea. I mentioned jacking/lifting above as this is something I try to address. This won’t release spring/shock tension, but this would deal with the tire issue, which is the bigger issue on shorter-term storage vs longer (year+). It’s likely be about as effective wrt tires and easier.
Old Nov 17, 2024 | 05:35 PM
85NBW's Avatar
85NBW
Thanks LeX2K for suggesting Ethanol Shield. 1 oz/gallon goes in tomorrow.
flex5150
Performance
Nov 4, 2020 02:15 AM
cripsy
NX - 1st Gen (2015-2021)
Oct 26, 2015 09:43 AM
Xxaaronxx
Sep 1, 2012 11:34 AM
ted920
May 7, 2006 07:08 PM
macpl
RX - 1st Gen (1999-2003)
15
Feb 24, 2005 02:35 PM
