Backfire !
Old Mar 27, 2023 | 12:30 PM
74Sprtstr's Avatar
74Sprtstr
Default Backfire !
i was wondering about that nifty backfire that occurs sometimes when downshifting with the paddles and no throttle. it gives you a little rimshot BRAP ,
every once in while, but not always. a backfire used to be thought of as a result fuel ending up in the exhaust manifold;
do you suppose this is the result, or is it by design, by having one of the injectors give a little squirt into an exhaust stroke ?
or maybe just a happy co incidence of both; either way, sure sounds good.
Old Mar 27, 2023 | 01:33 PM
flowrider's Avatar
flowrider
Veteran: Air Force
https://www.clublexus.com/forums/lc-...ackfiring.html
Old Mar 28, 2023 | 07:37 PM
CarbonC's Avatar
CarbonC
5th Gear
You know that you can unplug the exhaust valves (while engine turned off and keys kept at a distance) and wrap the connectors to protect them from the elements. Afterwards, there will be a permanent symphony of pops and backfires, without generating any codes.
rwhitwell
Mar 23, 2023 09:51 PM
Tyrant32
Feb 8, 2017 08:14 PM
Calliope
15
Dec 14, 2016 06:25 AM
verneyboy
Sep 19, 2011 02:31 AM
Lexbox
Mar 31, 2005 12:47 PM
