Faulty Stereo?
Old 07-27-14, 03:50 PM
aspeckt
aspeckt's Avatar
Default Faulty Stereo?
Disclaimer: Searched high and low on here for people with the same issue but to no avail.
Issue: My stereo keeps turning off on its own, switching to AM or FM, or ejecting CDs. One day it just shut off and remained off for 3 days. It started working again. Well today on my drive from Savannah to Orlando, the stereo went nuts. It kept turning on and off very rapidly for about 30 minutes. Then it shut off for good and didn't respond to the power button being pressed.
what's going on? ghosts? and I don't want simple answers like "check the fuse" something else must be at play here. If it were the fuse it wouldnt work at all.
Lastly, would a viable solution be, purchase the single din and buy an aftermarket CD player?
Thank you for your time.
edit: I also love playing music while I drive. it sucks driving without this so i'd like to correct this as soon as possible.
Old 07-27-14, 06:10 PM
Gville350
Gville350's Avatar
The audio portion of the center console unit is actually fairly cheap to find used. $100-200. But it's the issue that we still don't know if that would fix the issue. It could also be related to the amp in the trunk. I've read about those going out in a # of members rides.
Do you know if your center console unit has been removed ever? I have read of one case where someone's plug was actually loose and not completely plugged in causing all sorts of issues.
Old 07-28-14, 05:45 AM
aspeckt
aspeckt's Avatar
I don't think so, i've had the car since 2011 and it only just now started happening. so the amp controls the power to the unit? and not the speakers? because the speakers are fine I just wish i knew why it would turn on and off and switch modes on its on
Old 07-28-14, 06:38 AM
idoke1
idoke1's Avatar
That is weird. I would assume faulty unit. If all else fails, take it to the dealer to see what the culprit could be.
Old 07-28-14, 10:14 AM
littleyan9
littleyan9's Avatar
I have the same problem! but much minor than yours. My is250 will ocassionally "eject all" the cds. Sometimes the buttons on my radio will not work, and i will have to use the steering wheel controls.
It has never turned off on me though, or spazzed out.
Im intersted in knowing what your fix/change/plans are!
Old 07-28-14, 11:10 AM
MrBalistic
MrBalistic's Avatar
mine will sometimes cut about half the speakers off when I shift out of park, I would have to go back to park and restart the car, I have no dam idea why it does this.
Old 07-28-14, 08:42 PM
Mike285
Mike285's Avatar
I have the same problem. It started with just ejecting all the CD's. Then it started randomly turning the audio off. Now it turned off everything. The Nav the radio the climate control. Very annoying. By the way mine is Mark Levinison.
Old 07-28-14, 08:48 PM
aspeckt
aspeckt's Avatar
okay, glad to know i'm not the only one. this may be a bigger issue than i originally thought.
as stated by Gville, it may be seated loosely, because today i just pressed on the "Lexus" script to push that piece in, if i had come lose and voila... my radio started working again. perhaps vibrations from driving cause it to come loose every now and then????
Old 07-29-14, 08:38 AM
Mike285
Mike285's Avatar
I notice that when I push on the dash near the volume ****, that is when it usually started ejecting CDs
Old 07-29-14, 10:07 AM
aspeckt
aspeckt's Avatar
well that's weird. i might have an aftermarket sound place just take a look at it and see what the issue is. i dont want to go to my town's dealership. they hate that my is250 looks like an isf
Old 07-30-14, 06:05 PM
Mike285
Mike285's Avatar
also my mirrors cannot be adjusted either. this is very annoying
Old 08-09-14, 01:16 PM
Mike285
Mike285's Avatar
any luck fixing this?
Old 08-25-14, 03:53 PM
Mike285
Mike285's Avatar
I just replaced a fuse and that fixed my problem, not sure what caused the fuse to blow in the first place though.
rcftx68
04-01-16 10:52 AM
SEIDO
SC- 1st Gen (1992-2000)
12-08-15 05:15 PM
mofogasm
02-04-07 08:06 PM
marcmindte
03-15-06 11:05 AM
marcmindte
01-30-06 09:17 AM
Quick Reply: Faulty Stereo?
