Tow hook license plate
Old 02-26-12, 12:43 PM
dopestsgm
dopestsgm's Avatar
Default Tow hook license plate
Hi! This is kind of a dumb question, but i been searching and looking up, but i can't find the answer anywhere.
http://www.gominigo.com/Lexus.html
I want the tow hook license plate bracket, but they're way overprice imo. Where do you guys get yours for cheap? and I can't take off my tow hook cover. Its not even on the Owner's Manual.
Old 02-26-12, 12:57 PM
Sango
Sango's Avatar
I heard some may go go for $60 or something like that.
Not sure, I don't like that look on the right hand side. Just take off the front plate and go bracket free.
Old 02-26-12, 12:58 PM
Eric650
Eric650's Avatar
make one. real easy to do actually.
Old 02-26-12, 01:27 PM
dopestsgm
dopestsgm's Avatar
Do you have a link to it? Can you please send it to me?
Old 02-26-12, 01:31 PM
dopestsgm
dopestsgm's Avatar
I don't know where to buy the parts. Actually, I don't even know what its called You should lists out things for me to buy.
Old 02-26-12, 01:50 PM
Sango
Sango's Avatar
I remember asking a while ago on the forums and someone mentioned it but it was quite a good time ago so I don't remember.
http://www.rhoplate.com/Products-Lexus.html - This should work. Quick google search $60.
Old 02-26-12, 01:56 PM
CarbonDtls
CarbonDtls's Avatar
Looks dumb.
I use Loctite red double sided tape on my front plate and its been on there for a year and hasn't budged.
I can take the plate off anytime with a little pressure and it didn't leave any residue or pull the paint off.
The 3M red tape is nothing compared to the Loctite. I think the Loctite is rated at like 6lbs per foot or something.
Please note the front plate will not blow off, trust me I ran this thing in 60mph winds, major snow and rain. Its not something that you have to worry about coming off and being a flying object.
Old 02-26-12, 04:28 PM
ISCjonny
ISCjonny's Avatar
or you can make your own if you have access to certain tools... otherwise probably easier to pay $60.
go to your factory tool kit..
take the factory tow hook out...
cut the ring off the end...
drill a hole down the center of the shaft...
thread the hole you just drilled...
buy a piece of stainless sheet metal and cut to the size of your license plate...
figure out how you want to place the license plate and drill a hole on the sheet metal to attach to the tow hook shaft...
buy a bolt with low profile head that will thread into the hole on the shaft...
screw tow hook shaft onto car...
mount sheet metal to shaft and license plate to sheet metal...
Total Cost... Under $10.. takes about an hour...
Old 02-26-12, 05:57 PM
ms2619
ms2619's Avatar
I heard the same thing but how do you make one? anyone got a DIY ?
Old 02-26-12, 06:26 PM
Evitzee
Evitzee's Avatar
IMO that looks whack, it spoils the front end of car. Wouldn't be caught dead with that on my vehicle. Do it right or go home.
Old 02-26-12, 06:54 PM
axis77
axis77's Avatar
I personally bought the plate holder from RHO PLATE, http://rhoplate.com/
I never put the front license plate on as many of us never did but i got pulled over one day and didnt want holes drilled so i purchased the RHO plate. Good thing i did because when i went to show the CHP first thing they did was attempt to pull it off..assuming i had double side tape!. The officer was pretty impressed with the setup because it didtn make any holes , screws in your tow hook and you can easily unscrew it and pop back on the tow hook cover. to pop off the tow hook cover i used a very skinny flat head screwdriver pop one side off..pretty simple.
Old 02-26-12, 07:18 PM
Dustin2011
Dustin2011's Avatar
I picked mine up from here: for $70
http://thmotorsports.com/grimmspeed/.../i-495146.aspx
Then I did a search for a coupon code and saved an additional 5%. Not much, but it helped.
I really like mine. It was easy to install and keeps the plate rock solid. The thing I liked best was the plate mounting back plate is as large as the license plate. Therefore, I won't have any issues of my plate edges/corners bending.
Old 02-26-12, 09:14 PM
ZeroSeVen
ZeroSeVen's Avatar
Grimmspeed makes one for Lexus. It's fully adjustable where you can move the mounting bracket up, down, left and right depending on how you want it.
Old 02-26-12, 10:46 PM
Dustin2011
Dustin2011's Avatar
That is the one I have.
Old 02-26-12, 11:25 PM
dopestsgm
dopestsgm's Avatar
So how do you guys pop your tow hook cover off? Do you press from the bottom half of it?
Quick Reply: Tow hook license plate
