How to take front dome light lens out
Old Nov 23, 2008 | 09:36 AM
gizbx4's Avatar
gizbx4
Default How to take front dome light lens out
whatsup guys,
i recently purchased the Luxer Custom LED panels for the dome lights from Carson Lexus and i was wondering if anyone knew how to take the front dome light lens out.
I know you replace the regular bulbs through the back, by removing the whole piece by two screws inside the sunglass holder, but i need to install the panel through the lens because that is the only way it will be able to fit in. the led panel is custom to fit the lens exactly.
Does anyone know how to take this clear lens out???
i tried going through the back but there is too much wiring and circuitry back there to start taking things out, i don't want to mess anything up.
Old Nov 23, 2008 | 09:42 AM
Joe Z's Avatar
Joe Z
Lightbulb
Once you have the unit out, you should be able to push it through the back side but with something that doesn't dent the plastic... I think you can use the bulb holes easily..
or
You can use a small plastic pry tool on the edge of the lense so you don't mark anything up on your panel.
- Joe Z
Old Nov 23, 2008 | 09:50 AM
Zanorath's Avatar
Zanorath
CL Folding 25,000
When doing mine I started out taking out the 2 screws and pulling the console out, however, like you, I chickened out. I ended up just popping the lens off in the same way as the back. It is tougher however and will require more prying, I just a very thin screwdriver and it left 2 small dents where I wedged it in. I suggest using something that is fairly wide and sturdy, a credit card is too flimsy, but picture a metal credit card and that'd do the trick.
Old Nov 23, 2008 | 10:08 AM
pisaykotik's Avatar
pisaykotik
CL Folding 200,000
Originally Posted by Joe Z
Once you have the unit out, you should be able to push it through the back side but with something that doesn't dent the plastic... I think you can use the buld holes..
or
- Joe Z
I would do the former. I would use a blunt object that fits the bulb holes. Carefully pushing through each of the three holes. If I were to pry out the lens from the from I'm pretty sure there would be permanent dents. The plastic is too soft.
Old Nov 23, 2008 | 10:47 AM
gizbx4's Avatar
gizbx4
i was going to try and push it out from the inside but i was scared i was going to crack the lens. i guess ill give it a try later hopefully i dont break anything lol
Old Nov 23, 2008 | 11:04 AM
acefalcon2's Avatar
acefalcon2
do it as the lighting mods thread had done it.... it's easy.. there's no wirings that you have to take off.. it's easy ;D
Old Nov 23, 2008 | 11:23 AM
gizbx4's Avatar
gizbx4
ok the best method is like the first two guys said, using something that fits through the bulb holes and gently pushing it out from the inside. it comes out fairly easy. i tried a little prying before i tried this method, and all it did was dent the plastic
my1s250
Oct 6, 2012 01:23 PM
Yuri101
Jun 28, 2012 11:23 AM
Joeb427
Sep 24, 2011 02:24 PM
czerkawski
Jul 5, 2009 01:28 PM
Walnut
Apr 21, 2009 09:42 PM
