O-Ring for MAF?
Old Jun 16, 2020 | 09:20 PM
clarionguy's Avatar
clarionguy
Default O-Ring for MAF?
Anyone know the part number to replace the O-Ring for our MAF sensor?
Does not seem from diagrams there is a separate item.
I found this one that cross references with many other Toyota / Lexus MAFs but unsure if its the same diameter and fit.
90099-14141
Old Jun 16, 2020 | 09:49 PM
Can't find it in any diagram either, oversight? Rockauto doesn't have it either the picture shows the MAF with the O-ring on it. I found a picture do you have the old one to compare?
https://www.amayama.com/en/part/toyota/9009914141
Old Jun 17, 2020 | 08:40 AM
F_Throttle's Avatar
F_Throttle
That does not fit, I've tried it. I bought a loose o-ring from my local auto shop to make it work.. They didn't have an exact one so I chose one with a smaller diameter than the original one and stretched over the sensor. Try to match the thickness too or the sensor won't seat.
Old Jun 17, 2020 | 04:40 PM
clarionguy's Avatar
clarionguy
My maf oring was a tight fit on the RR racing tube intake piece -
Old Jun 22, 2020 | 10:26 AM
WhyHateTho's Avatar
WhyHateTho
Did you use lubricant?
Old May 15, 2026 | 05:48 PM
JRight's Avatar
JRight
9th Gear
Anyone have any luck and have a part number?
turtlepeas
Aug 24, 2017 04:39 PM
MattJO
GX - 1st Gen (2003-2009)
Apr 4, 2017 11:18 AM
durps
Nov 1, 2013 05:38 PM
Dx3
Jan 26, 2005 06:52 PM
