backwards compatibility- RCF/GSF engine into ISF
Looking into an eventual motor refresher for my ISF. I'm wondering if anyone has any first hand knowledge if the 2UR-GSE from the RC-F and GS-F is backwards compatible. I know they share the same architecture but how about ECU, sensor output, plug type and transmission compatibility. Does anyone know definitively? Please refrain for speculation, I can do that myself. Currently trying to arrange a side by side comparison.
Thanks
Thanks
The fuel systems are significantly different under the hood. The later model engine has three lines coming from the back where the early version has four. Not sure about the wiring, I haven't looked into it, but it would only make sense to do the transplant with the OEM wiring harness and ECM/TCU appropriate for the version. Integrating that might present some challenges from a wiring perspective. You'll also have to decide what to do with the air/oil cooler circuit - run it, bypass it, downgrade it to the earlier version.
I've been looking at this for a similar reason, and because the IS F would really benefit from the later engine because it's so much lighter than the RC F and GS F. Even the RC F Track Edition is heavier than the stock IS F.
If either of you do this, please fully document it for us. With the cost of building these engines, I’d rather upgrade to the newer version if I ever hurt my current engine. The upgraded fuel pressure and valve train components would be nice to have.
It would be a nice upgrade to the IS F. My concerns are similar to Lobux’s. To get the real advantages you need to use the RC/GS/LC engine ECU and it is basically one generation newer as far as electronics go. The Engine ECU communicates with the rest of the vehicle in a lot of ways, and most are probably similar. The biggest issue will likely be VDIM/ABS. You’d need to try I suppose, but I suspect the ABS ECU will be upset with the newer engine ECU.
Best bet in my mind would probably be to try to retrofit the newer ABS system along with the engine.
As far as the fuel lines go, you would need to ditch the return line from the high pressure side. 77024-53030 is the fuel pump hanger that would fit the IS F without the return line port. Other than that the lines are similarly located in both cars so I don’t think you’d need to do any further modifications.
Jeff
Jeff
Jeff
Jeff
For a stripped out track car, this would seem to be an easier proposition, but the devil is in the details for sure.
I’ve not experimented myself but I suspect the power control and immobilizer would maybe communicate properly with the engine ECU. Hard to know without trying it, having the engineering details, or being an engineer who worked on the components haha.
Would be fun for sure, though if I was just building a stripped out track car I would possibly consider other options.
Jeff
Jeff
I just perused the system diagrams of both the IS F and GS F. They are very similar, but have some substantial differences, and those include multiple CAN connections on the newer ECM. That could be truly confounding.
How about this:
https://www.clublexus.com/forums/is-...-is-500-a.html
RCF engine into a current generation IS.
Lou
Lou
How about this:
Lou
Lou
Thanks
Thanks
I've also looked into this option since I've had my motor rebuilt before and I only know of two other people that can say that. The fuel pressure for the RCF and GSF platforms are a lot higher around 3000psi and the fuel pressure for the ISF is around 1800psi so they are not compatible, It could work if you were to rewired the ENTIRE car including the instrument cluster.
I can't find hard evidence there is any difference in the high pressure injection pressure. Guess which procedure is from the RC F and which is from the IS F:
3. CHECK FUEL PRESSURE (for High Pressure)
(a) Connect the Techstream to the DLC3.
(b) Turn the engine switch on (IG).
(c) Turn the Techstream on.
(d) Start and warm up the engine.
(e) Enter the following menus: Powertrain / Engine and ECT / Data List / Fuel Press.
3500 to 4500 kPa (35.7 to 45.9 kgf/cm2, 508 to 653 psi)
If the fuel pressure is not as specified, check the fuel pump with filter assembly, fuel pump assembly (high pressure side), fuel pressure sensor and wire harnesses.
(g) Stop the engine.
(e) Run the engine at idle.
(f) Enter the following menus: Powertrain / Engine / Data List / Fuel Press.
(g) Check the high pressure side fuel pressure.
Standard fuel pressure:
3.5 to 4.5 MPa (35.7 to 45.9 kgf/cm 2 , 508 to 653 psi)
If the pressure is not as specified, check the fuel pump, high pressure side fuel pump, fuel delivery pipe assembly LH (fuel pressure sensor) and wirings.
(h) Stop the engine.
Powertrain > Engine > Data List
(f) Check the high pressure side fuel pressure.Standard Fuel Pressure:3500 to 4500 kPa (35.7 to 45.9 kgf/cm2, 508 to 653 psi)
Modified for truth. Our cars are not found in any serious competition. If they were, we'd have all kinds of options from a range of tuners. Toyota/Lexus just don't make cars people want to race in competitive series.
