Replace front OEM Bridgestone RE-050A tires with something else?
Thank you for the recommendation.
You make a good point. If I do decide on the bushings, would it be better to opt for the Figs version with the 80 durometer rating because it is less harsh? Figs LCA 80 durometer
^^^^ Thank you for your input. I've read a lot of complaints about still getting inner tire wear with the FIGS and RR Racing, so I've decided not to do it. Plus, with installation, it'll run $500.
Also, would it be better to run a little toe-in to offset the car's dynamic toe-out when braking?
There is new alternative to the Firestone Firehawk Indy 500 it's new General Gmax RS. I was looking to replace my existing tires with Firehawk Indy 500 the only problem is 255 35-19F will not be available for at least 60 days or more. And after replacing 2 set of pss , PS2 and now my current set tire all due to road hazards and poor road conditions bubbles on the side walls,Expansion Joints that had lifted up that I've torn my PS2s, recently the jagged pothole not cut my front tire and took a chunk my rear tire. I've spent thousands replacing tires prematurely. Since the Car spends 90% on local higways parkeays etc I would be happy with tires that can give me 8/10 performance similar to the top tier tires out there such as PS4s but without the expense associated with them.
A tech at tiretack told me of brand new tire that just came out that they recently tested tires week prior that he felt were on par with Firestone Firehawk Indy 500. All new General Gmax RS. And after speaking to three different technicians from tirerack on different days they all highly recommended the G Max RS they all stated it was comprable to the Firehawk but they all felt it had better wet traction with equal ride comfort one of the tech of felt Firehawk had a slight Edge in the dry but not much. The Genrals are made by Continental they come with it 45 day return policy if you're unhappy with them you can exchange them for another set of General or Continental Tires if I'm not happy with him I will exchange them for the Continental extremes. Price-wise there right on par with the Firestone Indy 500. They also took second place in Sema for best innovative new tire for 2018 they will also be coming on as Factory Equipment Tires on for new Saleen Mustang with 715hp G MaxRS are 360 AAA Y 186mph rated tires that are 2pounds lighter than the Firestone Indy 500 and the Michelin PS4s Heres just few links some I from Hotrod, Automobile and one other.
http://www.hotrod.com/articles/gener...ires-are-made/
http://www.automobilemag.com/news/pu...s-to-the-test/
i purchased these tire and will start thread once I have them mount this week.
The following 4 users liked this post by Weapon F:
BTW, on tirerack, they're about $150 more ($850 vs $700) than the Firehawks, at least for all four in the OEM sizes. But theres a $60 rebate on the Firehawks. I'm not sure if tires that are on backorder can be ordered.
Looking forward to hearing your review on the G-Max RS. In 255/275 setup them and the Firehawks are basically the same price on TireRack. The reviews look promising and yes, the lower tire weight, 2 pounds in front and 4 pounds in back vs. the Firehawks is good along with a higher speed rating, Y-186MPH vs. W-168MPH, and mileage warranty could make this the tire to beat in this segment.
Do you have experience with the Indy 500s for us to get a good back to back review?
http://www.tirereview.com/general-ti...mmer-uhp-tire/
Option 4 for sure. I am currently running S-04 PPs and am happier with those than any the others I have run in 10 years of ownership. Definitely spend the money on some lower control arm bushings for the simple sake of saving money on tires and then LOVE them for all the other benefits like better braking control, better steering response and increased stability. I preferred the RR Racing USRS design due to the increased caster designed into the brackets. But really the tire and braking benefit will come from any vendors LCA bushings.
On Tirerack there is there is $1 difference in price between Indy 500 and G Max RS in size that I'm interested in which is 255/35/19F & 275/35/19R, In 255/35/19 size as of right now from Tirerack up to 60 day wait or longer for this size. I called every Firestone dealer in tristate area and 10 different online tire retailer's NO one had that size.
