KCLV , obd fusion, 0-60 oh my
#91
Tech Info Resource
There's only one reason alcohol fuels are not so great. Lower specific heat than gasoline, so you need more volume to produce the same power which can mean reworking your fuel delivery system. Everything else about them from a performance perspective is a win. Significantly greater heat of vaporization, so you can run higher compression ratios (or more boost) without detonation concerns. Wider range of probable ignition, so your A/F can be a little farther off optimum, and the engine will still run (won't be best, but will at least get you in the ball park easier). There are downsides for sure, but not from a performance perspective.
#92
#94
I've had ethanol blends of E30-E50 in my car going on 3 years now and it sits in the winter sometimes for 2-3 weeks without any starting issues.....
#95
I don't think it's compatible..I just tried my bluedriver adaptor with OBD fusion and it timed out.
I also went through the PID and didn't see anything relating to knock sensor.
#96
Perhaps an ODB2 module and phone app will help me discover what’s going on with the stumbling and hesitation I’m getting at low RPM. Don’t remember it ever being this bad in the summer.
Do you all still recommend this app for data logging and telemetrics?
#98
Good to know. Chasing a power loss/hesitation/stumble without a CEL on an otherwise problem-free F and hoping getting live logging, knock correction, etc will illuminate the problem.
#99
#100
#101
There is a pid for misfire counts. I would check fuel trims on both banks as well.
#102
Guys I’m having problems connecting to my OBD.
just came back to my car, have the OBD unit connected to my car, switched on the engine and tried to find the WiFi connection to the OBD but nothing is showing up.
ive even bought a new OBD unit just in case this one was faulty.
the old one used to work in the past for sometime.
now when the engine is on I only get 1 red light on the OND unit.
does anyone have my idea how I can sort this connection issue out?
Do do you guys use WiFi or Bluetooth to connect to the OBD?
#103
Ambient temps are in the mid-high 90s, so I’m not shocked but not sure what to /do/. Fiancée and her father confirmed car feels weird earlier in the week and today, but right now it doesn’t feel too bad. I had a strange thought it could be a transmission issue actually.
#104
So can anyone help me out figure out my problem?
Firstly do you connect to the unit via WiFi or Bluetooth (I forgot it's been over a year)
Secondly any idea why the unit isn't showing up in WiFi or Bluetooth?
Thirdly When connected and the engine is on what lights are supposed to be switch on the unit? (I have stable red light and that's it)
