Suspension Rattle - 2012 F
Old 02-01-18, 03:46 PM
s2kjer
s2kjer's Avatar
Default Front Suspension Rattling - 2012 F
Lately I've noticed louder rattling noises only when going over bumps or driving on a rough road.
I just hit 100k and I'm guessing something needs to be replaced.... Bushings? Shocks?
Has anyone else experienced rattle noise around the 100k mark on their car?
If so what did you do to fix it? OEM or aftermarket parts?
Old 02-01-18, 05:38 PM
vraa
CL Folding Team Starter
vraa's Avatar
I just hit 100k and I'm guessing something needs to be replaced.... Bushing? Shock?
During the cold weather I had a sound coming from my front driver side suspension and I asked my dealer to check it out - they said everything was fine.
Old 02-01-18, 07:03 PM
BlckGhst
BlckGhst's Avatar
No suspension rattle. All I hear over very rough roads is a sunroof rattle
Old 02-02-18, 04:20 AM
newgsman
newgsman's Avatar
The thumping noise that shocks make is a bit louder when cold but otherwise my 2012 seems ok. I only have a bit over 30K.
BTW are shocks covered under the drivetrain warranty?
Old 02-02-18, 07:03 AM
ISFTOMMY
ISFTOMMY's Avatar
i had a knocking/thumping noise coming from the rear right of the car when going over bumps. turned out the seal on the shock was bad. lexus ended up replacing the shock under warranty.
Old 02-08-18, 06:41 PM
lawrence1
lawrence1's Avatar
My 2012 w/ 56k makes a sway bar end link tapping noise over certain road imperfections. Its also on the driver's side front. It started about 1k miles ago and i haven't gotten to it yet but i suspect it's either a bad front strut or strut mount as i already checked the sway bar end links and they look amd feel like new.
I'll be replacing both the strut and the mount in the spring with new oem parts. I actually did a search here and found several people with the same issue.
Old 02-08-18, 09:20 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
We don't have struts on these cars. The likelihood of the shock mounts creating noise is relatively small. I'd bet on swaybar bushings long before I'd bet on the shock mounts or bushings.
s2kjer (02-09-18)
Old 02-09-18, 07:21 AM
ISFTOMMY
ISFTOMMY's Avatar
found my old service records --( SERVICE: SHOCK ABSORBER ASSY 1-SIDE DESCRIPTION: SHOCK ABSORBER ASSY 1-SIDE ~ ~RIGHT REAR SHOCK LEAKING ..CHECK ~ ~RIGHT REAR SHOCK LEAKING. ~ ~31579 EXCESSIVE CLEARANCE : LEAKING REPLACED RIGHT REAR SHOCK ABSORBER. )
Old 02-10-18, 05:24 PM
lawrence1
lawrence1's Avatar
Good to know. I suspect i have a bad shock ... The swaybar end links and bushings look like new and feel tight. Will let you guys know what the results are when I get around to it this spring.
Old 02-11-18, 09:17 PM
chriso5573
chriso5573's Avatar
I bet you its your exhaust. Check behind the faux tips and see if there is any contact between the metal on the inside of the tips and the tip of the exhaust. I have this issue on my rear left side.
Chris
Old 02-15-18, 05:19 PM
lawrence1
lawrence1's Avatar
Chris
Im going to look at this first thing tomorrow
Old 02-16-18, 03:18 PM
Lecavem
Lecavem's Avatar
My 2012 with 52K does not exhibit any un-usual noises at all.
Old 03-01-18, 07:24 AM
lawrence1
lawrence1's Avatar
A quick update ... it is not the exhaust. Fairly certain it's a bad shock absorber on the front driver's side. I also have a wheel bearing starting to hum so that'll be taken care of at the same time. Unfortunately, the humming seems to be coming from the front passenger side. Not thrilled at the cost of a new wheel hub either ... nearly $500 incl. tax for the part. I called the dealer for a quick quote on the bearing and was told $1,000. No thanks.
Old 03-01-18, 09:03 AM
F Monster
F Monster's Avatar
Does it sound like this? I also have a rubbing noise coming from what I thought was the center console but had a passenger riding with me and told me it was coming from the passenger front wheels.
Old 03-02-18, 11:41 PM
glerink
glerink's Avatar
https://www.youtube.com/watch?v=06N8LhNj6PA&t=5s
In the case of the video it might be the wheel hub do to the fact that its a constant noise implying its thru rotation.
But to the op it sounds to me like it has to be maybe a worn shock or blown shock, worn/blown shocks tend to sound like a thumping noise when going over hard bumps, sway bar links loose or broken sound more like 2 metals smashing against each other and don't need a bump to cause noise and the sound is so bad that the car sounds like its falling apart lol
Quick Reply: Suspension Rattle - 2012 F
