Custom Exhaust Pipes - What would you do
So I finally received my Greddy Titanium Exhaust....it's a work of art but realized that I won't be road legal in the UK with these fitted as I'm also running PPE Headers, so I need to install Cats somewhere.
Instead of mutilating the beautiful titanium exhaust I'll have to sacrifice the pipes connected to the headers and build a custom stainless steel replica of the pipes below..
KJH I really hope you don't mind me using your pic for this demonstration, if you do please let me know and I'll change the pic.
The question I have is how would you go about installing the cats.
- Option one would be to make a replica of the pipes with resonators and install the cats in the area highlighted in Yellow below.
- Option two would be to have no resonators and simply install the cats in the same location as the resonators circled in red.
So Do I get the exhaust shop to install resonators and Cats, or simply just cats in the same location of the resonators below?
Any help would be appreciated.
Your cats run much hotter than the rest of the exhaust system, especially if you're supercharged. Accordingly, locate them as far away from the transmission as possible.
Will you be using metallic or ceramic cats? And, have you been able to source ones compatible with the greddy's 70 mm tube dia.?
I guess I'll only know once everything is installed.
Your cats run much hotter than the rest of the exhaust system, especially if your supercharged. Accordingly, locate them as far away from the transmission as possible.
They're 2.5" so around 63.5mm...I don't think it'll be a problem with Greddy's 70mm. The rest of the tube system will be kept within the same specs as the Greddy system.
No I had no idea the cats were also titanium....do you think I can source these separately and how would they do against the GESI cats in terms of abuse?
Also I doubt I can install titanium cats because the unit that will be built will be out of stainless steel....don't think I can weld stainless steel onto titanium....unless you meant getting a whole unit in titanium which now you've brought into my head .
So if you can find me a place that sells titanium cats that can withstand abuse then this will be a route I can look into.
Thanks for the info Rossi, will look into it.
^ What exhaust and header combo are you running?
When I had the Joe-Z installed they were beautiful in terms of sound, didn't really feel they were too loud but I did want to install Cats but never got around to it.
Kinda sucks you pay top dollar for the Ti just to replace the mid pipe. At this point I’d say look into applicable cats. I just don’t even wanna guess what those cost. Yikes.
My only gripe with the Greddy Ti, is the inability to add cats for a reasonable cost, and the fact they have a choke point right at the header. SS would allow adding cats AND remove that choke point with 2.5” piping like the rest of the systems offered.
