Lets play: What's That Horrible Sound! (Video)
Tech Info Resource
Yes, that's what I said. Who said they had this noise AND had a P0012 DTC? I surely didn't and I don't even to this day. I have no DTCs at all.
i can also confirm i have this noise but no P0012 DTC. I may have confused things by also posting in the thread about the P0012 code, sorry about that.
Im so confused now..lol...i pulled the valve cover and cleaned the OCV filter and swapped the OCV from left to right sides...lol..i still get the code...i run 10w30 in mine because of the high summer temps... my car was in the dealership last month for safety recalls for the sticky pedal crap and 5 others...but i feel like its because of them...they actually gave me the car back with the intake boot loose, oil pressure sensor not plugged in the ac compressor not plugged in and the coolant over flow leaking...i dont have this noise but i do have the code and it only comes on in high air temps 95°+ and idling..
Dropped the F off at the dealer today for the recall work, but didnt ask them about the noise as i think Lobux as pretty much nailed it. I ended up going to Lexus of Oakville, theyre much closer!
Tech Info Resource
I had a similar sound, but it went away after an oil change. I haven't heard it since. I also had my low oil indicator come on a time or two when parked at a pretty steep angle, so the car probably needed a top off.
Tech Info Resource
I run 0w-30 Mobil 1 right now, and I almost never hear it anymore. Anyone running 10w-30 or heavier is making a huge mistake. This engine needs oil in the top end quickly, so a 0w-30 is going to be your best bet. This tells me the drive sprocket is not the source of the leak, so spending the time, money, and effort to replace it would just **** me off. It really did go away completely for 4k miles after I did my last valve lash inspection and replaced all the seals in the valve covers, so I'm pretty convinced it's just a minor leak on cold cycle that gets sealed up as soon as the valve covers get some heat in them. It never, ever makes the noise when hot.
That said, I am switching to RLI Biosyn 5w-30 on my next oil change. I am hoping the noise does not return with this oil.
Lobuxracer, did your sound come on only during warming up or other times too? Did you ever experience any bogginess or jerky acceleration? I am not getting any CEL but getting a sound similar to you, and KCLV goes from 23 to 5 to 11 and all around. Car seems to do worse on highway and has issues shifting. 2012 with 52k, has the tuned intake and catless headers on it. Recently changed engine oil with 5w-30 synthetic , redline diff fluid, reset transmission and swapped out an intake elbow. Figured it was intake so swapped it back and issue comes and goes still. Took to dealer and they couldn't figure it out and with the tune told me to bring it back stock with a new computer so it's at shop now getting MAF and spark plugs done and diagnostic. When I dropped it off at the dealer it was running fine, but made the sound, on the highway it barely wanted to accelerate or drop gears unless in manual mode.
Update to this thread - 3 years later! A few weeks back (or maybe it was months, who even knows nowadays!) I changed the tensioner pulley and drive belt, and you know what? The sound is gone! I cant say this will be the solution for everyone, but my engine just “quietly” purrs along, with only the sounds of the lifters to lull me to sleep now.
When I replaced the tensioner pulley, the old one didnt seem to bad, no play in the pulley, but it was a bit louder than it should be when I spun it. The belt didnt seem horribly bad either, but I guess either one of them, or the combination of both was enough to make a horrible metal clanking sounds on cold start up.
-R
-R
The following 2 users liked this post by FNSSESPORT:
lobuxracer (06-08-20),
MileHIFcar (06-08-20)
Tech Info Resource
-R
-R
I wish mine were that easy. I replaced the tensioner and belt and it made zero difference with mine. Still have to replace the oil powered cam chain tensioner to address this, but truthfully I haven't heard the noise since swapping from Mobil 1 to Renewable Lubricants. That said, I bought a borescope and checked for the valley plate leak and found a very slight amount of pink crust in one spot and a little more noticeable leak toward the engine front on the passenger's side, so I'm planning to do all this stuff - cam chain tensioner, valley plate, and valve lash inspect/adjust when I hit 180k miles. Not quite there yet, and with as little as I am driving now, it might be a while before I actually need to do this.
BXIS250
05-16-19 06:49 AM
