245/275 Tire Combo
Old 03-07-17, 08:56 AM
  #46
MicahIS250
MicahIS250's Avatar
Maybe i'm crazy but to me this does not look like an SUV.
245/275 Tire Combo-dscf0042.jpg
The following 2 users liked this post by MicahIS250:
MpKSonic (03-07-17), spacexmase (12-19-23)
Old 03-07-17, 10:16 AM
  #47
newgsman
newgsman's Avatar
Originally Posted by MicahIS250
I was thinking the same thing, but I wasn't sure if going with a taller tire up front would cause rubbing issues. Wish I would have given it a shot now as the rear is absolutely perfect with zero gap although I am going to need to roll my fenders, has me wanting to lower the front a bit to compensate but it doesn't look bad at all.
You mention that with 275/35/19 you are going to need to roll your fenders. Are you on stock suspension. If you are having rubbing issues on stock height I may decide not to go with this size tire.
Old 03-07-17, 10:23 AM
  #48
Kojak77
Kojak77's Avatar
245/35/19 in the front
275/30/19 in the rear
RJMacReady (03-24-24)
Old 03-07-17, 04:01 PM
  #49
MicahIS250
MicahIS250's Avatar
I have only rubbed once and it was coming down a hill at a good amount speed over a dip. All other driving, bumps, dips etc I haven't had issues so far. I just want to have the lips rolled in to cover my bases. I think the size would and should work fine on a wheel that is less extreme. Rear i'm running 9.5" with +40 offset. I'm tempted to go back to the tire shop and swap my fronts out for 245/40/19s so the diameter front and rear are closer matched, and get some extra sidewall up front. Although running a +30 8.5" wheel i'm not sure if rubbing would be a concern or not with the added height. Here in Seattle the roads are atrociously bad so a little extra sidewall is welcomed by me. Get a nice tire with a stiff sidewall and the several percent difference really should not matter much. All and all i'm happy with my current setup, the lesser diameter up front seems to make no difference that I can tell, the added width feels nice, grips incredibly well. Much better than my stock sized Michelin PS3s on stock wheels.
I have a NX200t as well and it runs 225/60/18 tires. That is a more car like SUV I would say so the overall height is pretty conservative as far as SUV tires go. That's almost 30% more sidewall than either of the sizes mentioned. So I don't want to hear the suggested sizes are SUV like or cause any discernible difference at a few more percent than stock.
Old 03-07-17, 05:56 PM
  #50
newgsman
newgsman's Avatar
Thanks for the info. I have stock 2012 wheels with +55 offset in the back so I should be ok with 275/35/19 and not have to worry about rolling fenders.
Old 03-07-17, 08:17 PM
  #51
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
2012 wheels are +51mm offset, but I am running Michelin PSS in 275/30/19 on those wheels with zero issues. I chose not to run the taller tires, but who knows, it might actually be better from an overall perspective. Since no one is willing to publish the camber curves with either tire, it's difficult to say what really works and what does not.
Old 03-07-17, 11:51 PM
  #52
KraziAzn
KraziAzn's Avatar
just ordered 255/35/19 285/30/19 for stock 2012 rims and stock heights. gonna let you know if it'll fit.
Old 03-08-17, 05:52 AM
  #53
mikersoft
mikersoft's Avatar
You shouldn't have any issues whatsoever, unless you're slammed and/or have huge spacers.. Both are within spec for the wheel widths, plus they're pretty much the exact same O.D. as OEM (fronts are just .1 shorter). I'd probably be running the exact same set-up if Michelin made the PSS in 285/30/19 (I already have 255/35/19 in front).
-Mike
Old 03-08-17, 06:04 AM
  #54
newgsman
newgsman's Avatar
Which tire brand? Any deals out there? I was thinking Firestone Indy but I don't think they come in 285/30/19
Old 03-08-17, 09:53 AM
  #55
mk416
mk416's Avatar
The consensus for pre-'12 for size setup seems to be 245x35 and 275x30 for front and rear, respectively, and that is the setup I am going for once my rear are really worn out. (currently at roughly 25%)
The following 2 users liked this post by mk416:
RJMacReady (03-24-24), supersonic (03-14-17)
Old 03-08-17, 01:10 PM
  #56
Lextasy4
Lextasy4's Avatar
To each his own, but I think 275/35/19 in the back gives a more aggressive look than the 30. Shown above on a 9.5" +40 offset. Disregard the front tire as it is too small (these came off of my IS350). Zero rubbing issues on stock height.
Old 03-08-17, 04:16 PM
  #57
jdubbsISF
jdubbsISF's Avatar
I read through the entire thread and it sounds like this is the best option. The only thing I'm worried about is inducing more understeer with the 245 fronts. I'd LIKE to go wider than the 225/255 on 08 wheels but only if there are actual performance benefits at the track
Old 03-08-17, 08:27 PM
  #58
KraziAzn
KraziAzn's Avatar
-Mike
Yeah, stock heights and I specifically picked this combo to keep the rolling diameter as close to OEM as possible. Looking forward to the extra grip.
Toyo T1R Sport.
Old 03-09-17, 03:36 AM
  #59
Jz39
Jz39's Avatar
Attachment 405415
Yes, I stand corrected on the rear--that looks a lot like my 265/35 and I do think that might look a bit better than the 275/30 in the later pics. I can only imagine that the 245/40 though does not look similarly good, based on my experience with the 235/40 option.
Old 03-14-17, 03:15 PM
  #60
cameljock
cameljock's Avatar
I also plan to get the same setup. I bought a set Firestone Indy 500 with 245/35/19 Fronts and 275/30/19 Rears. I also plan to update the suspension with the Bilstein B6s. I'm still debating on whether I should A) use existing stock springs (2008 w/ 110k and a little sag) B) Buy new oem replacement springs or C) Lower with the Swifts.
I've heard a lot of complaints on ride quality with the Swifts. I live work in the NY area where roads can sometimes be atrocious. What do you think?
Quick Reply: 245/275 Tire Combo
