ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS F (2008-2014) (https://www.clublexus.com/forums/is-f-2008-2014-200/)
-   -   What's wrong with my car!? (https://www.clublexus.com/forums/is-f-2008-2014/846680-whats-wrong-with-my-car.html)
512ISF Feb 8, 2017 06:26 PM
i have a 2008 ISF and recently been having some very strange issues. I initially noticed my truck button inside the can was not working. Then while turning right my power steering seemed to momentarily go out while a plethora of dashboard lights came on. The brakes also seemed to catch or something during this turn. It has happened a few time when I turn right. Electronics flicker and the stability and power steering feels momentarily glitchy. Then today I go to start my car and it is stone dead. I plug it into to my portable jumper and it immediately starts back up and states my battery is at a normal level. On a side not me I noticed my rear window switches aren't working. The battery is less than 6 months old.
fstpassat Feb 8, 2017 06:28 PM
Typically this kind of stuff almost always means a faulty battery. Get it tested.
kauaian Feb 8, 2017 07:21 PM
Sounds like one or both of the battery terminals are not properly secured.
v8sedan Feb 8, 2017 08:38 PM
I'd start with a new battery too
mindcrime Feb 9, 2017 07:02 AM
check and clean battery terminals and cables. have battery and alternator tested. go from there.
MpKSonic Feb 9, 2017 07:36 AM
This is my same thought. Turning the vehicle causes it to flex, and if you put enough tension on a wire that is not properly secured, the connection may be intermittently broken. Double check that everything is clean and properly secured.
carmankyle Feb 9, 2017 07:38 AM
Just had this stuff happen to a client of mine on the same year ISF. Cleaned battery terminals, which solved the problem for a few months, then he called me and said he eventually just gave up and bought a new battery and it's been working ever since. Almost a year now with no issues.
F_Throttle Feb 9, 2017 08:47 AM
After the ELF campaign.. the dealer didn't secure my negative terminal... All my gauges went out while driving
