anyone getting the grom vline?
#886
https://gromaudio.com/software-vl1.html
There i only see the standard way to update the firmware... not if the display isnt coming... ?
You will need a USB flash drive. Make sure is freshly format FAT32 that is empty.
Download the file onto the USB flash drive and rename it gromvl1.hex
1. Before proceeding with loading the firmware,
Switch the radio to to FM before turning off and unplugging the Vline module
2. Switch Ignition OFF
3. Unplug the VLINE module from the vehicle
4. Insert the USB flash drive with the renamed file gromvl1.hex into the lower USB port (labeled USB2)
5. Reconnect power to the VLine module. Pay attention to the LED light on the USB drive, It should flash and then turn off. Once LED is off then the firmware is flashed/loaded.
6. After the firmware flashed, simply turn Ignition to ON position, then OFF then ON, wait for 10 seconds after Splash screen off, then press DISC button and see if it displays Vline logo or anything Vline related
#889
#893
No complaints? People are probably just using it without complaining since the issues are not going to end and they are tired of complaining. I sent the unit back for HDMI input issues and got it back without it being fixed stating it will be fixed with a software update. There are still issue seven with the 3.3.x.x. HDMI input does not work (only get video after unplugging power to vline and audio doesn't work), random reboots, very slow, and apps crashing. I just updated to the latest firmware v32 for gen 5 posted today and now there is no sound. The software still has bugs and is not very stable, it should still be in the beta stage. Other companies will consider this to be in the beta stage and not release it yet. How can vl2 be stable when vl1 still isn't?
#894
Can't you still get it through non-official channels? Didn't they say something about they can't just "officially" offer it due to licensing issues? Sounds like it might not be completely their fault.
#895
We've been in conversation with Android Auto team for few months. They had plans on releasing their SDK to us at some point, but it never materialized. We haven't talk to them for some time but you can get HeadUnit Reloaded and use that as you would Android Auto. Not sure if this is the big deal but you can run any app on VLine directly without too many limitations AA has.
#896
#900
And having AA run natively thru OS vs 3rd party app like HUR would make the system run even smoother.
