Steering Wheel Swap Detailed Walk-Through
Old 03-16-14, 01:41 PM
Vervish
Vervish's Avatar
Default Steering Wheel Swap Detailed Walk-Through
I know the video by Sewell is a very helpful when replacing your steering wheel, but I thought it was not very detailed on how to deal with all disassembly required to the steering wheel itself.
I tried to take some detailed photos on the removal of all the associated electronics.
Hope this might help someone who is a little hesitant to DIY.
Here is the Sewell Vid:
Next few posts will cover some detailed photos with regard to the wheel gutting.
Old 03-16-14, 01:42 PM
Vervish
Vervish's Avatar
I should noted that to remove the airbag clips you need to lightly pry this tab up and then pull on connector:
So after the Airbag is off, you will be looking at this:
You will need to unplug the ground and the 2 plugs on top, also make sure the wires are off the 2 black retaining clips:
Pull the wheel off and take it somewhere comfortable, you will only need a philips screw driver. It should look like this:
Old 03-16-14, 01:57 PM
Vervish
Vervish's Avatar
Next step is to remove the radio controls:
The control is held by one screw and 2 plunger tabs. Simply unscrew and pull off slowly.
Next, flip the wheel and carefully push out the tab holding the connector.
Old 03-16-14, 02:04 PM
Vervish
Vervish's Avatar
Next, flip it over and disconnect the connector:
You can now remove the connector, wiring and controls.
Next, you remove the cruise control (2 screws):
Old 03-16-14, 02:05 PM
Vervish
Vervish's Avatar
Once removed it should look like this:
I should note, that to this point all the screws and washers were exactly the same. However, the screws holing the shifters, looked the same but had some kind of anti-sieze looking green oil on the threading.
Flip over the wheel and unscrew the paddles. Take careful note of which one is right/left. Straight forward, 2 screws each. I set these "special" screws aside and made sure to reuse them on the paddles during install.
Also - note that there is a separate clip attached to the mounting points, make sure you note the orienattion.
Old 03-16-14, 02:11 PM
Vervish
Vervish's Avatar
Now, remove the paddles and flip the wheel around:
Remove this metal bracket, 2 screws.
Next, remove the 2 screws holding the plastic surround. Note that these screws are different from the others. Make sure to reuse them in the same place on install.
Finally, unclip the plastic here and remove the plastic cover:
Old 03-16-14, 02:17 PM
Vervish
Vervish's Avatar
Thats it - install is just like the disassembly in reverse.
Hope this helps clear stuff up for those who are hesitant to do this themselves. It took me 1 hour, start to finish..including the time for the photos. Super easy.
Here is a side by side or the aftermarket wheel and the stocker. Please ignore my 6 year old's juice (and the fact that I am standing on a chair to take the photo).
Old 03-16-14, 04:04 PM
cthemall
cthemall's Avatar
Nicely done This was my first and only mod on that car. I have the same flat bottom steering wheel from Sewell Lexus. It should've came standard with that steering wheel IMO.
Old 03-16-14, 04:14 PM
Mydogbella
Mydogbella's Avatar
Nicely done...good detail.
Old 03-16-14, 07:17 PM
digger08
digger08's Avatar
Nice write up......thanks for taking the time to document this.
Digger08
Old 03-17-14, 02:06 AM
Weapon F
Weapon F's Avatar
Great DIY post and pics quick question regarding new steering wheel. From side by side pic the bottom portion of new wheel looks thicker which is great but top portion looks to be same thickness as stock wheel or is it slightly larger diameter hard to tell in pic.
Old 03-17-14, 03:26 AM
Vervish
Vervish's Avatar
Thanks guys.
Thickness on top is about the same as stock, I cannot feel a difference. The new wheel is thicker between the 3 and 9 o clock positions.
Old 03-17-14, 06:41 AM
Vervish
Vervish's Avatar
More detailed pics of the differences. Honestly, I wish it was a little bit thicker..I had a Damd flat bottom wheel on my subaru and it felt thicker than the DCT one I just installed.
Old 03-17-14, 06:43 AM
Vervish
Vervish's Avatar
This is the one I had on my Suby.
Old 03-17-14, 07:02 AM
Kojak77
Kojak77's Avatar
I had the Prova D shaped in my STI, this install looks pretty similar.
Is there anything like the Clockspring in the Subaru that you don't want to disturb when you're removing the OEM wheel?
Quick Reply: Steering Wheel Swap Detailed Walk-Through
