who has had coolant leak around valley plate?
#453
I have not had an repairs directly associated with this leak, but I did lose coolant "ever so slightly" since I bought my F in 2014. After I changed my plugs in May 2017, I noticed oil on them and had the dealership replace the tube seals (three days before my CPO warranty was up). I mentioned the coolant to them as well, and they told me they found no evidence of the VPL.
After this repair, which included the part #s below for reference, the coolant stayed completely level until today. Last month it was on FULL, today it was about an inch below full. I couldn't see evidence of the leak today, but I'm going to dig farther this week and after I've reread this entire thread for the 10th time. I will say that this is the first season I've driven the car in the cold since I've owned it, if that matters.
11213-38060 - Cylinder Head Gasket x1
11214-38040 - Cylinder Head Gasket x1
11229-38030 - Cylinder Head Gasket x1
11193-38030 - Spark Plug Tube Seals / Gaskets x8
23224-38010 - Fuel Pump Gasket x2
23915-46011 - Fuel Pump Insulator x2
90301-A0029 - O Ring x2
11159-0S010 - Camshaft bearing cap oil hole gasket x2
If you don't already watch it, I highly recommend the show "Air Disasters" ("Air Crash Investigation" carries a different name but is the same show) on Smithsonian. The level of detail they go into is fascinating & they're completely respectful to the deceased. Your comment reminded me of this incident.
#459
No there is more stuff that needs to be removed, like injector clips that most likely will break. I mostly used the manuals that where provided in this thread. but in the end just ended up getting the 2 day subscription to this https://techinfo.toyota.com . that helped out alot
Justind27 (12-16-20)
#464
Agreed, so let’s stay on the topic of that.
1. I have already said in a previous post, that a gray sealant is used during engine assembly, not the black stuff. The gray is used to seal the entire engine. Valley plate, Timing cover, Oil pan. Everywhere sealant is used during assembly at the plant, its gray. This is across all engine platforms. See pics below.
2016 GS F block with valley plate removed. You can see the gray sealant around the edges. Don’t mind the hole, customer hydrolocked engine.
RX350 with timing cover removed. Same gray sealant, including around the inlet and outlet of the water pump where coolant flows.
2. It does not fail twice the factory sealant is different. It’s likely due to human error.
3. I highly doubt a judge would side with you and your lawyer & against the engineers at Three Bond. Best of luck with that.
Screen shot of email I received earlier today from Three Bond.
I rest my case. I can only hope that people will read through all 30 pages of this thread to get the facts.
The following 2 users liked this post by 93MSB:
lobuxracer (06-03-19),
s2kjer (06-04-19)
