Carbotech Bobcat (1521) - Use Factory Shims?
I recently installed 1521s all the way around. I didn't have an opportunity to bed them in initially but they were quiet. Finally got a chance to bed them in today (5 runs 60-30 per Carbotech instructions then 15 mins or so cruising with no stops). Now the car sounds like a Mack truck during low speed stops. Not just a squeal - it's embarrassingly loud. I read that Carbotech did not recommend using shims so I didn't. For those of you running these what is your setup?
Looks like I have found the source of the problem. There was quite a bit of discussion about this in some old posts back in 2010 so I assumed Carbotech had fixed this issue but my rear pads appear to be too wide for the rotors creating a groove from the rotor lip.
Here you can see the pad sticking out past the rotor edge when installed.
Tech Info Resource
Looks like Mike hasn't fixed that issue with the rears yet, but I'd bet he's hardly sold any rear pads. They just don't wear out at all.
I'd obviously change to some high temp brake fluid but I'm curious to see if it's worth even change the rear pad to a more track oriented pad. I'm just using regular stoptech street pads right now.
Tech Info Resource
There's more to it than wear. The torque characteristics will also impact bias - RR Racing already mentioned this in one post, and I think he's spot on with getting more rear brake by using a pad with higher μ in the back. I haven't tried it yet, but it definitely stands to reason. So, you might be very unhappy with the Stoptech rears depending on which fronts you choose.
I couldn't take the noise so I went back to Bosch QuietCast ceramics in the rear (Carbotechs still on front). Brakes are nearly silent now but the overall braking performance feels off and I'm sure the front is even more biased with this combo.
I agree with Lobux and Rafi that higher Mu in the back might be the way to go to give more brake balance. I have XP10 rears for track days but daily driving will never get the heat they need to perform so back to drawing board on this...
Tech Info Resource
Any of the Carbotech track pads are going to wear rotors fast if they are not at temperature. I would not run them on the street regardless of noise.
Didn't realize these had that issue until you mentioned it. I'm not going to go with Carbotech pads again. Thanks for pointing this out!
As I mentioned in a previous post, this sticker solves all your brake noise issues:
http://www.trackdecals.com/products/...-racecar-decal
AshyAnklez
IS F (2008-2014)
16
10-08-15 10:16 AM
xbladex00
05-31-15 08:33 PM
