Leaky car and burnt plastic smell
Hey guys, got the car(2008) about a week ago and have its 90k service coming up in 3 days however i just got out of it after a ~20 minute drive and noticed the strong smell of burnt plastic getting even stronger closer to the rear of the car, i checked under it and noticed a leak that was not there yesterday. Thought it could be ELF issue first as it hasn't been done on this car but the leak looks a bit far back under the car and it doesn't explain the stronger smell towards the rear, Ive attached a pic of leaks location could it possibly be coolant? Car got up to 3 bars temp fairly quick today i thought though it never went over even after several pulls from 20-80~
Thanks for responses curious if anyone else has had this or if anyone has ideas to what it is/severity of it. http://imgur.com/eAkuCWO (only sitting for about 30 seconds when pic was taken) |
Is it possible that is water from the exhaust and the heat coming from those leaks are burning the plastic that surrounds it?
I know a few members who have dropped the axle back who have melted their bumpers or other associated plastic pieces under the car. |
Originally Posted by Compthis
(Post 9168495)
negative on the bumper, all 4 sides of the car had normal temp. burnt smell has mostly dissipated but the leak is still there
Check the oil and coolant levels and see if any is missing fluid.
Any readings on the coolant temp gauge, is it running hot or normal? Usually when a car starts loosing massive amounts of coolant, the temp gauge will start reading hot, and that's about the time to pull over and shut off the engine. I am not saying that's necessarily the case here, but check the fluids. |
Originally Posted by 2URGSE
(Post 9168538)
in past cars, ive had a plastic bag melt to my exhaust and caused a burning plastic smell.
Originally Posted by DAng87
(Post 9168555)
Check for bags |
i didn't specifically get in there and check for bags although i did not see anything hanging from the car and it would not explain the leak that is new as of today, i will go check anyways thank you
shined a light up in there, didn't physically climb under the car to look but i wasn't able to find any bags.. was hoping to find that easy fix
you wont necessarily see an entire bag. generally what happens is the bag hits the exhaust. parts of the plastic melts onto the exhaust and the rest rips off but the plastic residue continues to melt to the exhaust and smells. I had burning plastic smell, assumed it was a bag and I looked but didnt see anything. recently looking under the car to jack up from the diff i saw where the bag used to be with some tiny melted plastic spots from where it hit but it doesnt smell anymore.
Originally Posted by liquidtek
(Post 9168696)
(Post 9168757)
I spent a half hour with a wire brush and scraper to clean the cat on the wife's Scion tC for this exact problem. And it was not possible to see the plastic until the car was up in the air.
My car pisses all over the ground when it is humid and I run the A/C. You're in Florida. You've never noticed condensation coming from your car when you park it before?
(Post 9168849)
