F1 - The diagram isn't clear enough which bolts. The yellow circles look like the control arm bushing bolts, and the red circle looks like one of the two steering rack bolts. Would need to validate which ones they mean. If they are what I think they are:
Yellow circle - 135 N·m {1377 kgf·cm, 100ft·lbf}
Red circle - 118 N·m {1203 kgf·cm, 87ft·lbf}
F2 - Green circle - 204 N·m {2080 kgf·cm, 150ft·lbf}
Yellow circle - 86 N·m {877 kgf·cm, 63ft·lbf}
Blue circles - 50 N·m {510 kgf·cm, 37ft·lbf}
R1 - Yellow circle - 127 N·m {1300 kgf·cm, 94ft·lbf}
Blue circle - 19 N·m {195 kgf·cm, 14ft·lbf}
R2 - Green circle - 127 N·m {1300 kgf·cm, 94ft·lbf} (Same as Yellow circle rear)
Wow.. you saved me
Thanks a lot !
I think the F1 yellows are these
Is this bolt same as you assumed in your precious reply above?
Any updates on these? a buddy of mine is planning to do this on his s2000 as spoon has a kit , so I wanted to see if anything would turn up here for the Isf, which brought me to your page
