Help with 2011 headlight upgrade
Old Sep 5, 2013 | 09:03 AM
Lexgendboi's Avatar
Lexgendboi
Default Help with 2011 headlight upgrade
Hi everyone, i did a search but nothing come up regarding the question im about to ask. So i want to upgrade my 08 headlights to the 2011 LED ones. My question is can i use my old bulbs and ballast in the new light housing? Or i would have to purchase a complete set? Thanks
Old Sep 5, 2013 | 09:48 AM
fasttexasz's Avatar
fasttexasz
Yes you can transfer everything from your 08 housings to the new ones.
Old Sep 5, 2013 | 11:14 AM
digger08's Avatar
digger08
.......except dust covers (which become round), city lights disappear and you have to cut your bumper brackets. Dual turn signal bulbs also change to a single bulb.
Digger08
Old Sep 5, 2013 | 09:50 PM
Lexgendboi's Avatar
Lexgendboi
Thanks guys for the help. Although im not exactly understand what digger08 meant by "city lights disappear" but overall...i think i got my answer. Thanks again
Old Sep 6, 2013 | 05:15 AM
jjpb5's Avatar
jjpb5
Its really easy to do. I cut out my ballasts from my old headlights and soldered them together. If you're handy with a dremel then you can use the old brackets. Also, the flasher relay is different because the new ones only use one turn signal. Lastly, you will have a flashing afs light on your panel. The cluster can be removed in 5 minutes and I put a piece of black tape over the light after I removed the gauge clusters cover. PM me if you have any questions. I've done this 3 times already.
Old Sep 6, 2013 | 09:14 AM
Lexgendboi's Avatar
Lexgendboi
Thank you jjpb5, i'll keep you in mind
Old Sep 6, 2013 | 11:47 AM
digger08's Avatar
digger08
Sorry......Its not a big deal and I used the wrong terminology....... there's a small "position" peanut or LED/ parking bulb in your housing beside the HID bulbs...it is no longer used in the new headlights as the LED strip takes over for it.
Digger08
vlone
May 8, 2019 10:35 AM
Fragger
Jul 17, 2014 01:21 PM
silvaIS
Sep 29, 2011 02:36 PM
KPinCS15
CL of Hawaii
12
Nov 6, 2010 02:03 PM
