Toms ISF kit... should a clear coat be added?
Just curious if anyone knows if the toms aero kit has a gel coat or clear coat. Has anyone added another layer of clear for protection? If so does the original layer needed to be sanded before a clear is added?
i believe its gel coat. My rear toms diffuser was smashed not to long along from a rear end accident and the clear didn't flake off like paint normally would.. Also from my experience in the past of re clearing CF, i always scuff the surface with high grit sand paper prior to adding another layer of clear. This is to insure that it stick well.
David, did you mean an actual clear bra as in film to protect the Toms, or just a clear coat? I'm discussing with my shop to see if I really need a clear bra on a CF piece. From what I have heard, CF pieces from Japan do not come clear coated, but rather a gel coat installed. It can't hurt to put an extra layer of clear coat to further reduce yellowing.
On 3k toms kit I'm trying to go the extra mile to protect it. I'm leaning on clear coating all the pieces to protect from the UV then clear bra on the front and side pieces. Putting on just a clear bra doesn't have any UV protection. Why does all the ****** cost so much. I need another hobby : )
I hope to be getting my areo function CF front lip spoiler in the next few weeks... I already have the Arkym rear diffuser and the e-bay CF roof spoiler... but they are not installed yet. Should I have them all clear coated before install? I was thinking of having clear bra applied to the front lip spoiler too.....
With the front lip, I'm not so sure I'd want a clear bra installation only because that's the one piece that will come in contact with the ground most often. The clear bra will protect the piece itself against debris and such, but it will get marred if you scrape it on a driveway or a speed bump. The film won't be as smooth after getting scraped, as it will form creases and won't look anywhere close to clear at that point. I would clear coat all the pieces for sure, however.
the thing people dont understand with clear bra, you have to make sure you polish out the part you are putting a clear bra on or you will see swirls, buffer trails, etc..whatever it is. also, a front clear bra can get chipped up to and honestly, it looks just as bad. i had my old front liip clear coated , drove about 20k high way miles and sold it not too long ago looking perfect. the buyer was amazed with the condition. its one of the little things ive learned from working in a body shop. clear coating headlights will make them look new for a long time as well.
Does the Velcro trick work? I heard it may help if you come in contact with the ground. Where and what size is everyone getting? 3" wide? I'm assuming the rough side is stuck on the spoiler.
As far as the clear bra goes the xpel bra is one of the best products i've used. Not sure if it self heals like they say but it will hold up over a clear coat any day.
