I hear a pop noise when rolling to a stop.
The noise I hear sounds like I ran over an acorn. It sounds like it's coming from the rear, but I can't be certain. When I notice it is at stop signs, rolling into my garage, or parking. I have heard the noise without pressing the brakes, so I don't think it's the brakes. I have 56K miles on it. Does this sound like wheel bearing issues?
Maybe suspension bushings?
I had a similar problem a couple of years ago, mine was definitely coming from one of the rear wheels. I thought it could be a bearing or brakes, it got louder as I was coming to a stop. While rolling (at any speed) it was like a constant grindind noise. After closer inspection (removing one of the rear wheels) I found a snail trapped betweeen the rotor and the shield! Its shell was intact, but the poor snail was cooked already! LOL.
Originally Posted by mugenh22a4
(Post 7277214)
Are the OEM Sway Bar bushings slit where I can pull them off the sway bar without removing the entire sway?
^^^ I crawled up under there and refreshed my memory on everything (I installed the rear F Sport sway bar on my previous IS350).
Should I stick with OEM bushings or go with something like an aftermarket poly-urethane? If I go with aftermarket, what size will I need? |
Maybe you are running over a lot of acorns hahahah
