oil level too high
I took my car in for the 10k service at a Lexus dealership a few weeks ago. At the time I didn't check the oil level but today I decided to check it and noticed it was about 5/16 of an inch above the high level mark. I was parked on level ground and the car was cooled(not driven since yesterday). There hasn't been any warning lights for what it's worth. I am going to call and schedule another appointment but I wanted to hear some thoughts as well. Has this happened to anyone before? Should I be concerned about driving it like this before taking it in?
it is probably not as bad as having too little oil. An easy fix is to aspirate the excess amount with a small plastic tubing and a syringe. you can get the tubing from any aquarium supply store. do this when engine is cold of course.
"A word of caution: Be careful not to overfill your car's crankcase with oil. If you put in too much oil, the engine's crankshaft can actually come in contact with the oil. And because the crankshaft is turning at several thousand revolutions per minute, it can quickly whip your oil into a froth — like the steamed milk that sits on the top of a cappuccino. Why is that bad? Well, the oil pump can't pump froth very well, and as a result, it can't get oil to the parts of the engine that need lubrication. The result ... a hefty boat payment to your mechanic."
here is the link.
http://cars.cartalk.com/content/advice/oilchanges.html
here is the link.
here is the link.
here is the link.
Does the high level on the dipstick represent the level of the oil in the engine and in the oil filter? Or is it only the oil in the engine? If so then maybe the excess oil is ok(as it would being going to the oil filter). What do you think?
The tube may be inserted too far into the engine or a O ring/gasket may be missing at the top. Either condition would move the mark up the dip stick.
If you paid the dealer to change your oil and it's not correct, I'd bring it back and let them sort it out. I would not recommend running to much oil. It's a bad thing. Alternatively, you could crack open the drain plug and CAREFULLY drain out a bit. It's tough to control how quickly the oil drains, however, so you might end up having to refil a bit.
CHECK ENGINE OIL LEVEL
(a) Warm up and stop the engine, and then wait 5 minutes. The oil level should be between the dipstick low level mark and full level mark.
If low, check for leaks and add oil up to the full level mark.
So stop thinking much too hard about how it might not be wrong or bad. It is unquestionably both wrong AND bad and needs to be corrected sooner than later.
FWIW, way back in 1991, Team Honda (Ray Plumb) figured out they'd get an extra 2 hp from their 600cc motorcycle engines by running them 1/2 quart lower than the manufacturer's spec. So you can figure all the team bikes were running a little less oil than the engineer's at Honda thought most prudent.
I always follow the procedure shown above, and as long as I'm not below the low mark, I call it good - if it's a little closer to low than full, I'm just fine with it.
