Drag Radials / Drag Rims discussion (merged threads)
Old 04-04-12, 09:22 AM
  #46
rexio83
rexio83's Avatar
if there wasn't a difference in weight, would the 275s show improvement over the 245s in traction? also i believe the 275/40/17 setup is sightly smaller in over all diameter compared to the 245/40/18 as well as stock 19s setup, will this affect the et or traps in any way?
Old 04-07-12, 05:16 PM
  #47
darbs242
darbs242's Avatar
275/40 is what I'm running and it works great
Old 08-29-12, 01:58 PM
  #48
Compthis
Compthis's Avatar
Default Mt slicks or BFG drag radials?
After changing out the diff on my ISF to the IS 350 diff, the tires skate and I want to take the car to the track to test it out. Will drag radials be good enough? I will never run nitrous in the car so I don't think I will need slicks. What do you all think? And I also want to pick up a set of rims, what size tires and rims should I go with, thanks in advance.
Old 08-29-12, 02:27 PM
  #49
rexio83
rexio83's Avatar
I run mt 275/40/17 on my isf with the 522 xxr wheels thanks to dv8, and I have to tell you once you heat them up, you won't be able to break them loose no matter how hard you launch, honestly I never thought a drag radial can stick so well but does, mts for life. Thanks again dv8, all the props to you for doing all the hard work and finding this set up.
Old 08-29-12, 04:26 PM
  #50
darbs242
darbs242's Avatar
im rocking MT 275/40/17 on volk re30 17x9.5 with +40 offset
Old 10-29-12, 04:36 AM
  #51
Gymkata
Gymkata's Avatar
Does anybody know if this setup will clear the calipers 17x9 +45mm Enkei Racing RPF1? I have been searching far and wide to find RE30s for a reasonable price, but to no avail. This is the next best thing I can find. I just got back home to the states and wanted to hit the strip, but I imagine by the time I could actually get this setup on my car all the drag strips will be closed for the year.
Attached Thumbnails Drag Radials / Drag Rims discussion (merged threads)-dr-setup.jpg
Old 10-29-12, 05:42 AM
  #52
MRxSLAYx
MRxSLAYx's Avatar
No!!! Ive tried and they dont fit. If you want to run an RPF1, you'll need to go with 18s with a +45 offset and very small spacer.
Old 10-29-12, 06:12 AM
  #53
Gymkata
Gymkata's Avatar
Thanks for the quick reply!
Old 06-17-13, 06:56 PM
  #54
KOKISF
KOKISF's Avatar
Default DRAG tires ,help!
i just whant to know wich size ,brand and wheel are you using im planing on getting them but dont know where to start
Old 04-25-14, 06:18 AM
  #55
ISFGEORGE
ISFGEORGE's Avatar
Default drag radials/slicks ?
looking for some wheel and tire size recomendations on some drag radials and street slicks for my F. Also did you guys go down to an 18 inch wheel to get more tire ? Any input is appreciated. Thanks!!
Old 04-25-14, 07:30 AM
  #56
caymandive
11 Second Club
caymandive's Avatar
245/40/18 MT Street ET's.
Old 04-25-14, 11:45 AM
  #57
VtotheJ
VtotheJ's Avatar
I'm running M&H Racemaster 245/40/18. They hook like no other....wish I could drive on the street with them! Too bad the treadwear rating is low
Old 04-25-14, 12:12 PM
  #58
ap2s2k
ap2s2k's Avatar
I bought mine yesterday from a member here, should arrive next week. They are Nitto NT05R's in 275/40/17 size , family member is running same size in Mickey Thompsons D.R., just posted a video on YouTube, he was kind of slipping of the line, mods are just joeZ and hps pipe.
Old 04-25-14, 06:28 PM
  #59
rexio83
rexio83's Avatar
Old 04-25-14, 08:40 PM
  #60
sr20bet
sr20bet's Avatar
Just curious if the slicks will add more stress to the overall drivetrain?
Quick Reply: Drag Radials / Drag Rims discussion (merged threads)
