And the "official" horsepower rating is... (merged threads)
#47
with lexus pricing i think its fair enough to compare the is-f to the m3, gt-r, etc. as a buyer you'd be considering the others anyway.
btw- 1sicklex- theyll say that no matter how engaging the auto is.
#51
At 416 hp, if that's the case, the ISF may not be top dog in HP but the performance figures are where it will win. Thanks to the new 8 speed tranny, the car will perform extremely well. I believe it will take the M3 and the RS4 and give the AMG a good scare on the strip. While doing this it will do what no manufacturer in this segment has been able to do; AVOID THE GAS GUZZLER TAX! To me, that is truly impressive.
#52
The C63 is just one of the cars that I'll seriously consider if the IS-F comes in at $60,000-plus (OTD).
Lexus may sell all the IS-Fs they can make given the limited quantities but I probably won't be an early adopter if the prices are that high. I have been planning on being one of the first but I'll wait and see the GT-R, the C63 and even the M3 and others before I spend that kind of money on a performance edition of the IS350.
#53
Rough ruff ruff
"The IS-F, with the least HP of the group, behind the C63, M3, and RS4, has the quickest 0-60, 1/4 mile, and slalom time of the group."
than
"The IS-F, although second most powerful amongst the four, was slowest to 60 and third on the track."
I think proving in performance number will turn heads and show "hey, this car is really ENGINEERED well..."
#54
I'm sure that's what you'd rather see, but that isn't going to happen.
#55
That is a European/Japanese dynograph where M3 is rated at 420 HP.
So far the best tested numbers so far for M3 is 0-60 mph in 4.3 seconds and 1/4 mile in 12.5 seconds@113 mph by Auto magazine Italy, which is not bad for a 3610 lbs luxury non-supercar.
If you look at the dyno curve closely, it is spread-out so it makes the curve "seem" falling off steeply below 3000 rpm.
It still make atleast 365 Newton meters between 1800 rpm and 8100 rpm, which is 90% of it's total torque. 365 NM = 267 ft-lbs of torque. So above 1800 rpm uptill 8300 rpm, it will be making atleast 267 ft-lbs of torque to a maximum of 295 ft-lbs of torque.
That is what a massive powerband is called where 90% of the torque is being produced between 1800 - 8300 rpm for a 6500 rpm rev range.
Not to mention the 3.91 rear end final drive (thanks to the ability of manual transmission for handling high stress) while here is the equation:
Wheel torque = crank torque X (total transmission ratio i.e. gear ratios, final etc.)
Curb weight of the car.
That explains why a Porsche 911 GT3 with 299 ft-lbs of torque and 415 HP runs a 3.9 second 0-60 and 12.0 seconds 1/4 mile.
IS-F while the 373 ft-lbs of peak torque is very impressive for a 3750 lbs car, with a tall 8 speed gear automatic stack, 6800 rpm redline and 2.1 rear axle ratio, it will need to make best use of the crank torque to be fast in a straight line.
One more reason for me to be frustrated by Toyota/Lexus relentless efforts to kill all manual transmission cars by not even offering it as an option.
#58
Reuters claims 423 hp here: http://www.reuters.com/article/tnBas...17344420071004
Also this Motortrend forum post (which cites the Toyota press release) now says "Actually it's 423hp not 417" but I'm not sure where they're getting it from: http://forums.motortrend.com/70/6429...3-f/index.html
#59
According to http://lexus.jp/models/isf/spec/spec.html, the weight of IS-F (without a moon roof) is already 1690kg (3755 lbs!!). The footnote said even more increase by 20kg (44.4lbs) when the moon roof is added. I am not sure that it will be also true for IS-F in US but this is a sad news anyway...
#60
With the emissions equipment on to meet the regulations for US market, 417 HP in Japan/Europe will translate to around 409 - 411 HP.
p.s. Redline as per specs is at 6800 rpm.
