Maintenance while doing upgrades
Old Jul 21, 2023 | 10:43 AM
inovashn's Avatar
inovashn
Default Maintenance while doing upgrades
On the verge of pulling the trigger on ordering and or installing
UEL Headers/ceramic w some 90degree extenders for downstream 02
x-force Varex exhuast
RR pulley combo set
Oil change (best I've read is that Mobile 1 doesn't agree with our cars) any suggestions on preference here is appreciated (I assume stock filter replacement).
RR Road and Track USRS along with
RR R2 road and track coilovers
08 with 38k mileage stock everything that I know of or looked at
Any you might as well do this or that while your at it
Like water pump/02 sensors/spark plugs/ or new belt for pulley etc
Any feedback with anyone with higher mileage and or knowledge of whats coming up or should be looked at would be great.
I don't want to get 3/4 the way through it and/or finished and be like
I guess I should of replaced this along the way or I wish I did whatever while doing x or y
Old Jul 21, 2023 | 11:39 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
At that low mileage, there's not a lot to worry about although the O2 sensors might be difficult to remove without damaging them. Depends on where the car has lived most of its life. If it came from the Rust Belt, I'd buy O2 sensors (all four of them) just to be sure I won't be waiting around for parts because the originals are corroded in place.
Old Jul 21, 2023 | 01:56 PM
MileHIFcar's Avatar
MileHIFcar
Yea @ 38k your engine is basically brand new and not even broken in yet, you shouldn't have to worry about much unless what Lobux said above needs attention other than that your golden besides the elected modifications you want to do to your car.
Old Jul 24, 2023 | 05:30 AM
inovashn's Avatar
inovashn
Thanks guys
3 owner car before myself.
Ny for 2/3 of its life...It had to be garage kept and brought out in summer with zero weather
MD/VA for a bit and then NC make up the other 1/3
If a car could have less rust on it at this age it would be still sitting in a showroom (only reason I bought it being where it was from/driven)
Any advice on the oil type/brand?
or 02's to scoop?
Old Jul 24, 2023 | 09:12 AM
mferg02's Avatar
mferg02
I never heard that about mobile 1, I've used exclusively that on my is f for the past 25k miles or so. Haven't had an issue yet, what have others experienced?
Old Jul 24, 2023 | 05:23 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Bad wear numbers compared to other brands, and it's not tolerant of fuel dilution which is common with the factory tune. There are much better alternatives. If you have a good sharp tune, Mobil 1 might be just fine, but the analysis results I got and the subsequent discussion is well documented.
Old Jul 24, 2023 | 05:33 PM
mferg02's Avatar
mferg02
I searched when I first read this post and didn't come across any threads about it. Can you point me in the right direction? Has me kind of worried now. I literally just got back my oil analysis from blackstone too and it seemed like everything was good. But I am no expert and this is the first time I have every seen this type of report. I have the factory tune still. Also, what alternatives are people using? My searches before came across others saying they use mobile 1 plus the oem filter, which is what I have been doing since I got the car at around 80k miles. My report is below as well:
Old Jul 25, 2023 | 10:33 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Blackstone can't tell you anything substantive about fuel dilution. They don't have the proper equipment to perform anything but a very rudimentary fuel dilution test, and it's a hack at best. Your iron wear numbers aren't bad, they're actually better than mine on my IS F but almost twice what I see on the GS F. I've been running Renewable Lubricants PCMO SHP 5W-30 for a pretty long time now. Lots of 5 gallon pails stacked up in the garage...
The GS F sees 4 ppm iron consistently on a 5k mile oil change. The IS F iron came down a little from a high of 14 ppm to 10 ppm after switching to RLI PCMO. There is a thread in the RC F forum on oil, and you can read the analysis of my Blackstone reports there:
https://www.clublexus.com/forums/rc-...ml#post9783463
The thread is pretty large, but the most valuable part is the first 5 pages.
Old Jul 25, 2023 | 10:40 AM
mferg02's Avatar
mferg02
Ahh ok, I will check it out. Thank you for the info. Where do you pick up the "Renewable Lubricants PCMO SHP 5W-30" from? Also, how much is it? Sucks because I've always picked up the mobile 1 at Costco and it is usually on sale for 35 for 6.
Old Jul 25, 2023 | 04:32 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I order it direct from Renewable, or I get it from Amazon. Depends on who has the better price that week.
Old Jul 30, 2023 | 09:47 AM
CLass of 1's Avatar
CLass of 1
I have never heard of renewable oil…wow! How does this compare to Amsoil? It seems like Amsoil and Royal Purple are the “best” when you read online. Wondering what your take is having used this renewable oil.
Nick
rwagoner
Jun 28, 2022 02:09 PM
TechGreek
Mar 8, 2011 06:32 AM
durtysc300
Jan 26, 2011 11:03 AM
Abear
GS - 1st Gen (1993-1997)
Apr 17, 2007 08:28 PM
Och
Feb 14, 2003 01:57 AM
