IS C Discussion about the convertible IS C model
TPMS giving false indication
Old Jan 13, 2024 | 10:12 AM
Mike246's Avatar
Mike246
Default TPMS giving false indication
My beloved 2011 IS250-C is indicating low tyre pressure with an orange symbol on the dash display. The symbol flashes then goes steady-state. I have checked all 4 tyre pressures, found them correct and added a few extra pounds however the indication remains. I have tried doing a reset without success.
Do any of you guys have any ideas?
Old Jan 13, 2024 | 10:54 AM
axel's Avatar
axel
It is probably a bad sensor in one of the wheels. Same thing happened to our 2012 IS350C a while back. A tire shop can check which wheel has the problem and replace the sensor. I think it was around $100 here in California...
Old Jan 13, 2024 | 05:45 PM
imkIS350c's Avatar
imkIS350c
It is mostly likely dead battery. You can get it replaced at Costco for 60$.
Old Jan 14, 2024 | 03:08 AM
Mike246's Avatar
Mike246
Thanks to you both for your responses which are equally valid.
Here in the UK we have Costco and I have total faith in their tyre department. It's time to get the two front tyres and sensors/batteries changed out.
Why do we Brits spell tires differently? I'll have to check this out with my wife who is New York born and bred and retains her US citizenship.
Old Jan 14, 2024 | 08:46 AM
imkIS350c's Avatar
imkIS350c
Glad we were able to help. Change all 4 sensors so that they won't give you headache again.
Old Jan 29, 2024 | 10:25 AM
Mike246's Avatar
Mike246
Well, what appears simple . . . .
I went to Costco who diagnosed one failed sensor and another with low battery. Both were replaced however their equipment would not marry these to the ECU.
The fitter told me this has been an issue with Lexus models but weirdly not with Toyotas. No safety concerns as the tires are holding pressure.
My local dealership would charge £185 ($ 300) for an hour's labor although this is a 5 minute job. Do you guys have any suggestions?
Old Jan 29, 2024 | 12:41 PM
imkIS350c's Avatar
imkIS350c
Sorry to hear that. It's not surprising that dealer charges 300$, considering you need a specific tool to register new sensors to your car. I personally use an Autel Bluetooth OBD tool, which cost about $50, and the BeadBuster XB-450 for changing the sensors myself.
Dealerships often charge a hefty sum for OEM sensors, and you could end up spending around $700 in total (Labor+parts).
I would leave it alone. I know it's frustrating to have that light on your dashboard, but the cost may not justify the fix.
Old Jan 29, 2024 | 12:57 PM
MikeFig82's Avatar
MikeFig82
From what I've seen the ISx50. They come factory set up for main, and winter tire setups.
The same ID codes are registered on both setups. Problem is after you get a failure, and replaced with a new one. It wipes all the codes. So you're stuck with them programed only on the "Main" option.
Please refer to this post, and look at the link added there. It instructs on how to set up a dual set of TPMS. Your manual that came with the car should indicate this aswell. I suspect your TPMS is set on "2nd" while the sensors are programed to be on "MaIn"
https://www.clublexus.com/forums/is-...l#post11625420
Visual video how to access the settings.
Old Jan 30, 2024 | 04:09 PM
2013FSport's Avatar
2013FSport
Post Tpms pn - 42607-33021
I recently replaced all four with new Denso for $75 shipped. Wrote down the sensor ID's in notepad and pasted that into Techstream 1 by 1and it took less than 4 minutes to register them all. It was pretty simple.
Then I handed the sensors marked Front and Rear to the tire guys and had new rubber installed. Problem solved. 350 production date was 2012-12, sold in March of 2013. Sensors were still working 2023-11 when they were replaced but showed mixed values for battery state.
So, 10 years is okay by me.
TPMS PN - 42607-33021
Old Jan 30, 2024 | 04:24 PM
swfla's Avatar
swfla
Besides Costco, national chains of tyre shops can also do the programming. Try one of them. Best to do the spare as well as some years and models will give you a total error light if any single sensor is malfunctioning. Newer models are more wheel specific.
Old Jan 30, 2024 | 05:26 PM
lexo98's Avatar
lexo98
Year, make and model? Does your UK version show actual wheel positions like the US model? What part number did Costco install?
Old Jan 31, 2024 | 06:32 AM
Mike246's Avatar
Mike246
Well, it seems with a curious mix of luck to judgement I have this sorted without a visit to a dealership.
The TPMS system hold data for two sets of tires, presumably summer and winter. The ECU setting was on '2nd' rather than main. I changed this and the warning lamp extinguished.
A visit back to Costco confirmed that they had programmed the two new sensors to the ECU so it seems all is well.
Shame that the Costco chap missed this minor point after all his hard work of fitting the sensors.
lexo98 - the sensors are EZ SENSE T2200 model. These operate at 433 Mhz. I have not encountered that actual wheel positions are indicated.
Old Apr 3, 2025 | 04:00 PM
jcg0324's Avatar
jcg0324
I don't think the TPMS system was ever meant to give precise tire pressure information. It does do a good job giving a warning when the pressure in one or more tires is getting low. Not a bad deal.
bagofchips
RX - 3rd Gen (2010-2015)
Oct 11, 2023 10:00 PM
chileboy
52
Dec 7, 2022 03:02 PM
jagtoes
May 23, 2022 04:24 PM
right360
Nov 18, 2021 05:08 AM
linkzx
Oct 19, 2018 11:42 AM
