Lexus IS 500 GSF / RCF Brake upgrade
The stock rear brakes seem up to task even from mild track use, but I wouldn't mind having matching blue OEM F calipers for the rear too.
RCF/GSF front caliper upgrade on the way
Hoping to get the dust shields from IS500 ultimate edition to complete it with OEM parts. Any one have part numbers for those or know when/how we can find it?
got the below for awesome prices during the 1776 4th sale from Prestige Lexus
Hoping to get the dust shields from IS500 ultimate edition to complete it with OEM parts. Any one have part numbers for those or know when/how we can find it?got the below for awesome prices during the 1776 4th sale from Prestige Lexus
Blue Right: 47730-0W160 ($287.33)
Blue Left: 47750-0W160 ($287.33)
Shim Kit: 04945-0W020 ($12.83)
Fitting (pin) kit: 04947-0W020 ($27.58 x2)
Plan to by below from Rock Auto for RCF/GSF:Blue Left: 47750-0W160 ($287.33)
Brembo OEM pads: P83154N ($57.79)
Brembo OEM right rotor: 09C26621 ($118.79)
Brembo OEM left rotor: 09C26611 ($119.79)
Need IS500 UE dust shieldsBrembo OEM right rotor: 09C26621 ($118.79)
47782-53070 - Backing Plate, Front LH
Jeff
Production of these backing plates started last month. You can likely get them on order with a local dealership, but it may be some time before they are readily available, and definitely some time before you'll see them populate in online sources.
Jeff
It's a brand new part number, you won't find anything about it online. If you Google that part number, most/all results are for other part numbers instead, because there are no results for these specific part numbers. Read the results you're seeing carefully.
Jeff
Jeff
Very awesome! Hopefully the price point is about the same. I would gladly spend 70 - 90 bucks rather than chopping up an oem piece.
Jeff
Jeff
I did the same...searched and came up with older model backing plates then once Jeff putted it out, I realized the part number coming up was slightly different. Hoping the price is similar as well and definitely prefer buying a new OEM part and being able to save the stock ones.
