Spoiler upgrade!
Old Dec 8, 2022 | 10:28 AM
  #31
dk12's Avatar
dk12
Originally Posted by lojackfty
i was hoping the holes would be the same between the two of them, but now I'm not sure. Thanks for the picture of the original one, it helps.
I actually tried the dhp spoiler they are not the same holes, it annoying cause they're only off by half an inch but it will not work unless you drill new holes. Luckily I was able to sell mine locally to a 350 owner, I wish I could've seen this thread sooner and I could've offered more insight.
Old Dec 8, 2022 | 06:57 PM
  #32
MYIS500's Avatar
MYIS500
I have a Seibon spolier set to arrive Tuesday or Wednesday of next week. This spoiler looks great from what I can see here. It is racy enough, while still maintaining overall Lexus class.
Old Dec 9, 2022 | 06:37 PM
  #33
MYIS500's Avatar
MYIS500
Originally Posted by Velobrew
Here are some side shots, sorry not the best background.
Question. How did you remove the plastic bolt/clips holding the trunk lid liner in place?
Old Dec 13, 2022 | 01:48 PM
  #34
LA20671's Avatar
LA20671
I would probably get a DHP trunk or 350 with the cf wing on, if you dont want to drill holes and keep it oem. lol.. otherwise, that will be hella $$$$$$$.
Old Dec 13, 2022 | 04:23 PM
  #35
MYIS500's Avatar
MYIS500
My Seibon spoiler came in today. Looks like it is going to pop right on. Bought some neoprene rubber washers and some silicone sealant just in case I need it.
Old Dec 13, 2022 | 05:13 PM
  #36
MYIS500's Avatar
MYIS500
Well this is on hold. Removed the trunk liner easy enough with zipties that I passed through the slots of the fastner heads. Problem is my hands are to big to reach the bolts on each end. I will have to wait for a friend to help out. Even if I could reach them, I think you still need two people. One to squeeze the stock fastners and one to lift up on the spoiler. Will post pics when completed.
Old Dec 13, 2022 | 05:22 PM
  #37
DaOne's Avatar
DaOne
Originally Posted by MYIS500
Well this is on hold. Removed the trunk liner easy enough with zipties that I passed through the slots of the fastner heads. Problem is my hands are to big to reach the bolts on each end. I will have to wait for a friend to help out. Even if I could reach them, I think you still need two people. One to squeeze the stock fastners and one to lift up on the spolier. Will post pics when completed.
I had to use one of those flexible extension things. The one that looks like spring to install mine.
Old Dec 13, 2022 | 05:26 PM
  #38
MYIS500's Avatar
MYIS500
I'm not sure what you're talking about. You used that to hold the nut onto the bolt?
Old Dec 13, 2022 | 05:30 PM
  #39
DaOne's Avatar
DaOne
Yes, to hold/torque the bolts. The two bolts at each end of the spoiler are too deep and hard to reach.
Old Dec 13, 2022 | 05:33 PM
  #40
MYIS500's Avatar
MYIS500
Gotcha, what is that tool called, I need to get one ASAP!
Old Dec 13, 2022 | 11:44 PM
  #41
lojackfty's Avatar
lojackfty
does everything line up and is there bolts all the way across or does it have only the two on the end with snap clips
Old Dec 14, 2022 | 12:24 PM
  #42
MYIS500's Avatar
MYIS500
The stock spolier has two bolts and four pushpins for lack of a better description for a total of six. The Seibon has six M6 bolts with nuts and washers. It aligns perfectly. The grief is putting the washer,nut on after you put the spoiler on. The area there is a tight fit to reach. I decided to add neoprene rubber washers and silicone around the holes when I do the install. Just need to buy the right tool to reach that tough spot.
Old Dec 15, 2022 | 01:25 PM
  #43
MYIS500's Avatar
MYIS500
Yes they did.
How did you remove the pushpins?
Old Dec 15, 2022 | 06:38 PM
  #44
MYIS500's Avatar
MYIS500
The stock spoiler does not come off easy. I am still trying to work at it. Ugh! I may have to nix this for the time being. Simply cannot get those pesky pushpins loosened/free/off.
Old Dec 16, 2022 | 08:07 PM
  #45
DaOne's Avatar
DaOne
Did you get it done? Share pics.
