IS 500 advice
Old Nov 24, 2025 | 08:29 PM
  #76
jltarra's Avatar
jltarra
Such great detail.
Your car looks mint!
Old Nov 24, 2025 | 08:32 PM
  #77
jltarra's Avatar
jltarra
Originally Posted by Benibiker1558
I use this Apple CarPlay dongle and it works well:
CarPlay
It starts up within 10 seconds and is very stable. Every now and then, like once every two months, at start up the screen may be blank although playing music. Those times I just unplug it from USB port and plug it back in and good to go.
I’ll keep this in mind once I sort the disconnecting issue. Thanks
Old Nov 30, 2025 | 04:04 PM
  #78
jltarra's Avatar
jltarra
Does anyone know where to find the SOS fuse, keep in mind my car is RH drive and is a Japan import and I'm not sure if the US cars have this feature.
Thanks in advance!
Old Nov 30, 2025 | 04:37 PM
  #79
wthrman2's Avatar
wthrman2
I am far from an expert but it appears that it falls under the telematics section (labeled DCM) under the engine compartment fuse box
for the IS 350, it would be located here (you can maybe look in your diagram in the owner's manual if its the same)
​​​​​​https://www.startmycar.com/ca/lexus/...o/fusebox/2024
I am not saying I am right but maybe worth looking to see if you can find that one
Old Nov 30, 2025 | 04:41 PM
  #80
jltarra's Avatar
jltarra
Thanks, I'll give that a try later and let you know how I go.
Gr8Car4Me
ES - 7th Gen (2019-2025)
Mar 28, 2019 06:34 PM
Serf27
IS F (2008-2014)
31
Apr 6, 2016 09:06 PM
941tuned
Jul 12, 2013 07:49 PM
DrifThug
Mar 17, 2009 08:58 PM
