The service rep told me that they have not been able to find an issue but they will let one of the mechanics take it home to test out some more. No indication that the gas was bad thus far, but they will let me know more tomorrow.
Originally Posted by LexLight
(Post 11560927)
It's really sad to see how Lexus is going down like this. Checked ES subforum they got a Fuel seepage notification until 2022 model year and then in the RX subforum they have many issues related to Engine (not surprising given how the Tundra is plagued with issues due to massive powertrain changes) and the Dash coming off first model year but those problems are a bit too much.
People buy Lexus for a massively superior experience over the modern automobiles with a ton of issues and long term issues plus the lease mobiles becoming money pits due to inferior engineering, shortcuts and planned obsolescence. And Lexus being opposite are failing at it, I can only express my massive disappointment, look at Lexus LS the car which made the brand it got just abandoned for good. Also a small note, YTer Samcarlegion who based IS 500 he also got the 2022 IS 500 with issues sitting in the dealership. Lexus need to get their things correct esp with such a good engine 2UR GSE and it has been there since IS F, yea it is changed but still Common Lexus this is a 65-70K vehicle....that too you make these IS 500s at Tahara which builds the legendary 4Runner and built some solid cars.. Takumi craftmanship and all that. With these kind of issues popping up related to fuel pumps, no wonder why old Land Cruiser and the good ol GX with no D4S system just big NA V8 1UR series with Port injection only just simply run forever. Add the 4Runner to the lineup. As much as advanced as it sounds and props to Toyota Motor Corp for making the D4S unlike the carbon plagued GDI engines of the world this is a complicated system without a doubt. To the OP, hope he gets the IS 500 repaired properly, Good Luck. Also just in case make sure you check out the Lemon laws in your State if the car is constantly getting into the dealership under 24 months. Forums will typically scare most folks from buying any products but especially an automobile. I don't think Lexus is going down. If they are, they're still #1 in the U.S. The OP has an issue with his car, it will be repaired, hopefully, under warranty along with others from the other forum subsections you mentioned. Regarding the YouTube dude, I typically ignore car reviews based on track times and pointless drag racing. https://cimg5.ibsrv.net/gimg/www.clu...2f43553968.png |
Originally Posted by Kappa500
(Post 11561264)
That was a lot to follow....
I've never owned a Kia, but I had. Genesis G70 and it was pretty rock solid. I'd say it's no doubt the best sedan available without a V8. Yeah, better than the 3 series, the A4 and the C-Class....not counting RS, AMG and M variants.
Genesis has gained more ground than any other manufacturer....not counting Tesla who is still too new. |
FWIW, my LE hasn't had a fuel pump issue at all, im right at 6k miles. Wouldn't be surprised if it did happen though. Cars that have come in for fuel pump recalls recently have been coming back a second time for a fuel pump failure because a subpar part was supplied. Toyota and Lexus mainly sourced Denso parts, but due to the chip shortage crap, they've been taking parts from anyone who can supply them. I think that is causing a massive issue.
Originally Posted by Pittsy
(Post 11561457)
What info are you basing that claim that they are just taking whoever has parts? |
Originally Posted by arentz07
(Post 11561514)
You sure it's not because of underglow? :D
(Post 11561514)
What info are you basing that claim that they are just taking whoever has parts? You can go to your local dealer and ask their technicians how much they like the new NX and RX. They'll tell you, lol. Actually, my fuel pump did stop working. Blew the fuel pump fuse. good news is, I installed my new underglow by wrapping the copper wire around both legs of the fuse, and now it works again. :wiggle: |
(Post 11561663)
I’m with @arentz07 on this one … wouldn’t hurt if we all just took a deep breath. I’m guilty of it myself having been on the front end of the CEL exhaust issue and Lexus went above & beyond in standing by their product.
https://cimg0.ibsrv.net/gimg/www.clu...b282f06ab.jpeg Besides, just scrolling to the end of this thread you will see ‘related topics’ for other Lexus models from years ago that have suffered similar problems (screenshot above), some of which (like the LX470) have since been proven to be amongst the most reliable cars ever made. |
Originally Posted by TipsyTonio
(Post 11561682)
Sounds to me like you followed the TIS Repair Manual. Akio approved!
I was under the impression you should use a fuse tap when you want to connect two accessories on the same fuse, but I could be mistaken. |
Originally Posted by lexussingh
(Post 11563833)
Isn't that advised against?
Update:
They still can't reproduce the issue, but after reaching out to Lexus, my dealership was advised to replace the "purge valve". Hopefully, this fixes the issue, and it is not the fuel pump that is going out. |
(Post 11563833)
I was under the impression you should use a fuse tap when you want to connect two accessories on the same fuse, but I could be mistaken. you’re correct; an add-a-fuse is the correct method. |
(Post 11561423)
| All times are GMT -7. The time now is 05:15 AM. |
