Getting 20mm B0noss spacers
I’m planning on getting 20mm b0n0ss spacers on the front and back, just a quick question will I need extended wheel bolts for the front and back or no?
for some reason it’s censoring b0n0ss when I type it normally lol
I started with 15/20 mm b0noss spacers, but I changed to 15mm square setup. I still have my 20mm set laying around. I see that you are also in NC. If you want, you are welcomed to pick up my set for free. It had it on my car for about 4 months.
heck yeah that’d be awesome! I’ll DM you!
also what made you switch from 20’s back to 15/20? Did you have any issues with scrubbing? I really like the look of 15/20 I just wish the front was a bit more flush so I’m trying 20/20
Also he was saying that he was 15/20 and went back to 15/15 because the rear was too aggressive of a spacer for his liking. So he only has 2 20mm spacers for you if that's what you're looking for.
No rubbing or anything like that. I think the rear stock alignment has a little negative camber. Visually, the 20mm rear spacer makes the lower part of the tire stick out of the wheel well. Plus, I plan to get 275 rear A/S tires this winter. I anticipate the lower part of the tire will stick out even more. Last reason is that I installed a titanium stud conversation kit. Having different spacers will make a difference on the exposed titanium stud, i.e., the exposed rear stud will be shorter than front.
I've never seen anyone do the 20/20 on stock wheels. It's usually 15/15 or 15/20.
