Engine Cover Removal
Old Apr 8, 2024 | 07:36 AM
FirstLexusIS500's Avatar
FirstLexusIS500
Default Engine Cover Removal
Hi Everyone. Are there any tricks to removing the engine cover? I have searched and haven't found instructions. I don't want to pull/push/slide in the wrong spot. On another (non-Lexus) car I owned there was a sequence to removing the engine cover - pull up in the back and slide forward. I didn't find out that correct sequence until after a broke a front clip. Any help would be appreciated.
Old Apr 8, 2024 | 07:53 AM
arentz07's Avatar
arentz07
Just gently pull up starting from either the front or the back on a corner. There is not really a trick to it. The engine cover is just held in by some little pegs that slide into some fairly soft rubber-ish grommets.
Old Apr 8, 2024 | 08:12 AM
FirstLexusIS500
Perfect. Many thanks!!
TCM55
IS F (2008-2014)
Jun 3, 2021 12:28 AM
Ltaboso
IS F (2008-2014)
12
Feb 4, 2015 11:56 AM
jbl-1985
Sep 9, 2011 08:51 PM
SC3coupe
Jul 10, 2010 02:46 AM
SC3coupe
Jul 7, 2010 04:38 PM
