CarPlay vs Bluetooth Audio
Old Sep 20, 2022 | 06:42 AM
jtrue28's Avatar
jtrue28
Default CarPlay vs Bluetooth Audio
Apologies if this has been discussed, I attempted to search and find older threads about it.
Speaking about my 22 IS350 F-Sport. I've noticed that if I plug my iPhone in, to use CarPlay, the audio sounds horrible. Nothing I do on the phone will make it sound any better. I've adjusted the settings for the car sound, but it's still bad. And this is with the ML system.
When I just allow the phone to connect via Bluetooth, it sounds fantastic. Adjusting the volume on the phone works like it should and also changing the EQ settings in the phone works as well.
Is there a hidden setting somewhere that I'm missing to allow the CarPlay sound to be better utilized.
Thanks!
Old Sep 20, 2022 | 07:29 AM
PrimeDave's Avatar
PrimeDave
On your iphone go to settings - music - EQ - select "flat" see what that does. Toggle between flat and hip hop or whatever genre you like and see if that affects anything while its playing thru the car speakers. Example: My EQ is set to "hip hop" which does change how it sounds as you toggle between different selections. But I change it to rock or whatever depending on what i'm listening to. Its a long shot but maybe "flat" will fix this.
Old Sep 23, 2022 | 06:13 AM
jtrue28's Avatar
jtrue28
When the phone is connected (via wire) for CarPlay, nothing that I do on the phone makes any changes at all to the music/audio coming out of the car. I've stopped using CarPlay. The difference in quality of sound between these two options is night and day. I'm actually really impressed how good it sounds now. Thanks.
Old Sep 23, 2022 | 01:34 PM
arentz07's Avatar
arentz07
I haven't noticed any difference in sound quality with Android Auto. Just curious if you have tried different cables to connect your phone?
Old Sep 24, 2022 | 11:30 AM
jtrue28's Avatar
jtrue28
I’ll give that a try. Thanks!
Ruzifan
Dec 8, 2021 12:21 PM
abapper
Oct 12, 2021 12:33 PM
wallaceb
Jul 22, 2015 10:52 AM
Rexus300
May 7, 2014 10:20 AM
wase4711
HS 250h Model (2010-2012)
13
Jul 10, 2013 08:30 PM
