Scraping noise while driving, stops when braking
Old Jul 3, 2022 | 08:27 PM
a714143012's Avatar
a714143012
Default Scraping noise while driving, stops when braking
Scraping noise while driving, the noise goes away when I press the brake.
Any of you guys experienced this type of situation before?
Old Jul 4, 2022 | 12:07 PM
RA050224's Avatar
RA050224
If it stops making the noise when you apply the brakes, it could be the brake pad (or rotor?) wear indicators. Older cars used to do that, not sure if Toyota/Lexus uses that type of system these days.
Old Jul 5, 2022 | 01:06 AM
wongnee's Avatar
wongnee
also check these:
one of mine failed and had some noise.
Old Jul 5, 2022 | 02:30 PM
swaangin's Avatar
swaangin
Originally Posted by wongnee
also check these:
I believe this is the wheel hub (1 possibility). And mentioned above, maybe brake indicator, seems counterintuitive but you will hear metal clanking when your pads are near the end of it's life. You will know it's metal to metal when the brakes start grinding on the rotors
rns
Hybrid Technology
13
Mar 31, 2023 07:42 PM
pinoiryder
Feb 7, 2011 09:50 AM
ChrisM910
Apr 25, 2006 01:41 PM
nardeezy
Mar 29, 2006 07:32 AM
