Reverse camera staying on when I put into drive
Old Aug 7, 2021 | 03:56 PM
Byrnew's Avatar
Byrnew
Default Reverse camera staying on when I put into drive
Hello,
Over the last couple of weeks twice I noticed when I was in reverse and shifted into drive thr reverse camera stayed on thr screen while I moved forward . I stopped and put it back into reverse and then drive and it was fine. I could have shifted the gear lever doen fast without giving it time. Would this be the reason or has anyone else had this issue .
Thanks
Wayne.
Old Aug 8, 2021 | 05:00 AM
Sasnuke's Avatar
Sasnuke
What year/model of 3IS do you have?
Do you have any aftermarket electrical accessories on the car?
The multi display shows the camera image based on the Reverse signal it receives. Once you shift out of Reverse the signal is lost, and so is the image.
If the image is still there in Drive, then something is still feeding the display a Reverse signal.
One possible cause for this is an aftermarket accessory, but other things could cause it too.
EDIT: I saw your other post about the gearbox oil, you have a 2014 IS300h.
Old Aug 8, 2021 | 11:46 AM
Byrnew's Avatar
Byrnew
hiya Thanks for the reply . The only thing I have is a dash cam thats plugged into a USB socket but that doesbt connect to thr screen . It has only happened a couple of times when I think I didnt give thr car enough time and change the gears fast from reverse into drive and took off so maybe there was a delay in the signal . Well thats what I am hoping.
Old Aug 8, 2021 | 02:48 PM
dojoman's Avatar
dojoman
This has happened to me a long time ago didn’t know what was the caused I thought it was cool seeing camera while driving. Maybe just a bug.
Old Aug 8, 2021 | 03:24 PM
Byrnew's Avatar
Byrnew
haha it was strange looking alright 😄 thanks for the reply . I'm going to go slower while changing into the drive modes and monitor it fromb there and hopefully it was just a bug and it doesnt cost me lots if it was to get worse .
Old Aug 8, 2021 | 06:20 PM
dseag2's Avatar
dseag2
Mine does it frequently. Always reverts back so no big deal. I did make the mistake of leaving my trunk open when I reversed the other day and I was looking at the trees and sky. That's a better way of telling you your trunk is open that any bell! (Also, I realized I posted in the wrong forum but went into Edit and couldn't delete. My bad.)
Old Aug 9, 2021 | 12:49 AM
Byrnew's Avatar
Byrnew
hi, thanks for the reply . Haha defo a good way to tell if the boot was open 🤣
Old Aug 11, 2021 | 11:52 AM
TLeexus's Avatar
TLeexus
Originally Posted by Byrnew
Hello,
Thanks
Wayne.
i wish mine did this on purpose
Old Aug 11, 2021 | 01:53 PM
dojoman's Avatar
dojoman
You can buy a switch made by Beatsonic to turn on reverse camera with a button. It's not cheap though costs about $200 It's for front view camera but also has input for backup cam.
Grigsbyt1
Feb 23, 2021 04:32 PM
texlex11
GX - 2nd Gen (2010-2023)
Sep 23, 2019 08:52 AM
GoHuskers
NX - 1st Gen (2015-2021)
25
Dec 20, 2017 07:53 AM
FatherTo1
Jul 21, 2016 10:32 PM
