Anybody have the answer to remote start via key fob WITHOUT a subscription to Enform?
I posted in the maintenance forum as well, but I thought I’d take a crack in this one. My wife has a 2015 IS250 AWD w/ navigation and premium package. I’ve tried the 3 clicks of the lock button to remote start via the key fob and no dice.
Strange thing is, my 2016 RX450H does remote start via the key fob. I have NO subscription to Enform, never have. I didn’t even buy my RX at a Lexus dealership.
Why would mine work, and not hers?
Received 1,732 Likes
The 3 press Lock button method of remote starting the vehicle is based on the vehicle having the remote start equipment physically installed in the vehicle.
At that point it is purely a function between the vehicle and key fob.
Likely the original owner/purchaser of the RX had it installed at the dealer...to which the dealer should have placed a sticker on the driver and passenger door window glass...usually at the back of the glass at the bottom...straight up from the door handles.
The stickers should be there...but as they are only stickers, they could have not been installed or removed...especially if the glass has aftermarket tint.
As for the Enform I have nothing really to offer as I'm in Canada and Lexus/IS never got Enform...actually only a few vehicles have it now for the last couple years.
As far as I'm aware, without the Enform you cannot remote start the vehicle, unless you have a physical remote starter unit installed...which I'm not sure they ever had for IS...at least they didn't in Canada.
This is just a strange mystery. Lol!! I’d call the Lexus dealership, but they’ll probably tell me I need Enform.
My 2014 Highlander has the Toyota Remote Starter physically installed...it uses the 3 Lock press method to start it.
Toyota doesn't have Enform or any other subscription type service.
I'm not sure all the details of the Enform, but maybe it's possible you can use the remote to start the vehicle.
As the Enform start feature works via cellular service, it's possible the vehicle could disable the key fob remote start function when it realizes the subscription to Enform has ended too.
Car has the option but I think Lexus / Enform service, when you unsubscribe, alter something in the ECU to remove the functionality.. it's actually really messed up.. Idk why they would do that.. forcing you to get a subscription.. on top of that, Enform is run by Verizon network.. not sure if Lexus even gets any benefit from it. This Winter I chose not to get it
My dealership "installs" the key fob feature (where you can use OEM keyfob and click 3 times) for $300 + tax... lmao.. I know they're not doing any installing, it's literally robbery
Nxplicable (01-09-23)
I'll give a useable answer here,
Get the dball3 remote start setup, it utilizes the oem key fob and you can do the remote start with it via 3 clicks of the lock button.
I have had it on my prior LS and the lady's IS - zero issues.
Parts are like $50 and wiring it up takes under an hour.
The only notable difference is that the Toyota one you have to hold the Lock button on the 3rd press for a couple seconds...the 12V Solutions one is just 3 normal presses of the Lock button.
Here is another video of the CSI remote start, which functions the same as the 12V Solutions one:
I just installed the 12Volt Solutions remote starter on the 3IS a few weeks ago and it works great with 3 clicks of the lock button. Here is a link to the one I purchased (i purchased during Black Friday sale... normal price seems a bit high):
https://www.12volt.solutions/product...32076308250727
They also offer long range remotes and an app but I did not feel they were worth it. Very simple install, all plug and play (no wire splicing or cutting) and the hardest part was removing interior trim.
Feel free to PM me any questions or ask here and I can go more in depth.
I saw a different brand on Amazon but there were a few reviews that stated a) the kit stopped working after roughly 2 weeks, or b) one person said their kit came with a label that said it had to be installed and activated by the dealer, so he returned it.
The good: Finally installed a remote start kit. Was actually pretty easy, and it works great.
The bad: Steering wheel now rubs the plastic behind it. I took the plastic shroud off 3 times to line it back up - the spaces around both stalks are even, so it looks straight and good. But still, the lower portion of the shroud is clearly getting rubbed by the steering wheel. My few car buddies are out of town for the weekend, so I'm on my own trying to fix this.
Anyone else had this issue?
EDIT:
FIXED!!! Got up early this morning and took the entire driver's side section apart, took my time, and got everything lined up properly. No more rubbing. *insert super silly happy dance here
EDIT:
DPD0927
Performance
10-19-17 07:37 PM
