can not do 2014 3IS RWD Transmission fluid flush.
Easy enough to find a shop that will do a drain-and-fill. As mentioned, the one I just went to has ex-Lexus and Toyota mechanics, and they do a double re/re where they run the car a bit in between.
When mine was done an at independent shop they did 2 drain/fill, and drove the car a bit inbetween. Used a synthetic fluid which I preferred OEM, oh well.
I don't have my invoice to see how much fluid they used but im 99.9% positive it's nowhere near 4L for a single drain/fill. Maybe 2-3 qt.
Does that sound right? Single drain/fill and charged for 4 liters of fluid?
Received 1,732 Likes
You'll get about 3L or 3 quarts out of a drain and fill.
A Litre and a Quart are fairly close in actual volume, so depending how hot, or cold, the fluid is will depend on the exact amount you get out, but it will be approx. 3L, or Quarts.
Is that the difference between the 6 and 8-speed?
I'm almost at 70K so am thinking of doing the transfer case and diffs in December, then looking to start doing the tranny.
Thank you for all your quick replies. Now at least what they told me is true that they can not do the full fluid replacement. Still pissed that they did not inform me prior to just drain and fill. At least I made sure they did not charge me for a flush but a drain & fill. They knew I was pissed so they did give me a small water-proof Bluetooth speaker as a courtesy for that. They charged for parts/labor $85.98 CAN.
Lexus dealer in Ottawa was around 350$ tax in for all 3 services, independent Toyota tech did a drain n fill for around 90$. I also used AMSOIL signature series fuel efficient ATF instead of Toyota ws.
Not sure if it’s different with the 8 speeds but on the AWD model transfer case fluid is changed when u do tranny fluid. I thought it was separate jobs but dealer explained they share the ATF fluid and when you get tranny your also doing transfer case fluid.
Hmmm, well when Lexus quoted me on servicing they had it separate. One of their services had transfer case in it, and they quoted the tranny flush as a separate procedure. All good though, I'll just do the diffs later this year. The shop quoted me about $80-90 each, sound right?
Yeah that's no problem, I just drop it off in the AM before work. They can do it later in the day if need be, but they should at least be warmed up so they'll flow out better.
Just double checked my bill from Lexus. They had transmission/transfer case as 1 job... 174$ total for that particular job.
Yea I meant cold like ambient temp, fluid level drain plug only is accurate when the fluids between 40-45 degrees Celsius, any hotter and the tranny will be under filled because more will come out the fill plug. Where ever u go make sure they 100% understand the job because usually what happens is they check trans temp when it’s to hot, they see a bunch of fluid come out the drain straw and think “nice it was overfilled slightly now it’s good” when really it’s under filled now because they checked to hot, fluid expanded and more drained than what should have. Lexus has a TSB saying so many trannys were getting underfilled and only to do it at Lexus because independents were checking the fluid level at wrong temp.
AtomicAWD (07-10-19)
