Lifetime Transmission Fluid What's your highest mileage
Old 04-22-19, 08:34 AM
  #46
NickCaesar
NickCaesar's Avatar
Originally Posted by little2576
i'll do Diff/Trans/Engine Air Filter every year,
Does anyone have a ballpark cost from the stealership doing this above ?
Lexus dealership in Ottawa charged me $320 for trans fluid/front diff/rear diff...
engine air filter is a $25 part you can do yourself in 5 minutes.
Old 04-22-19, 03:53 PM
  #47
GiN4tHeWiN
GiN4tHeWiN's Avatar
hmm, i'm at 118k miles.. bought the car brand new, haven't changed anything regular engine oil, tires, and brakes.. and windshield wipers once.
should i get my transmission fluid changed? how much is the typical charge for that?
Old 04-22-19, 04:07 PM
  #48
VisualEcho
VisualEcho's Avatar
You should have your diff fluid checked/changed pronto! But the trans fluid, well, that's up to you apparently.
Old 04-22-19, 08:20 PM
  #49
Isaac88
Isaac88's Avatar
I'm at 70,000 miles and my dealer said they don't have a "flush" machine, so the best they could do is just drain and refill.
Should I find a place that can do a complete flush or would a drain and refill be sufficient?
Old 04-23-19, 06:06 AM
  #50
AVIAT0R
AVIAT0R's Avatar
Does a complete flush cause damage? Under what situation would it cause damage if any?
Old 04-23-19, 09:28 AM
  #51
VisualEcho
VisualEcho's Avatar
Originally Posted by E46CT
The "flushes being bad" stories are old wives tales. Flushes is a stupid word anyway. I've talked about this at length on bmw forums where some criticise replacing fluids on high mileage trans as a precursor to failure because you've now dislodged crud which was holding things together.
This is what I've heard in the past, but it's been a long time. My issue was more a Honda/Acura bad trans, which has always been the case with them.
Old 04-23-19, 10:56 AM
  #52
CLUM
CLUM's Avatar
Old 04-23-19, 11:19 AM
  #53
GNS
GNS's Avatar
Does anybody know if the AWD IS's transfer case oil can be changed? I know that the differentials and transmission fluid are serviceable, but what about the transfer case? I heard that on some BMWs, the transfer case for the xDrive system does not have a drain plug, which seems insane to me. You'd have to take apart the underside of the car, pull out the transfer case and literally tip it over in order to drain the fluid.
Old 04-23-19, 11:25 AM
  #54
VisualEcho
VisualEcho's Avatar
My Lexus tech friend didn't mention servicing it at all, just the front and rear (mine is AWD as well).
Old 04-23-19, 11:30 AM
  #55
GNS
GNS's Avatar
Thanks for the info, would you be able to ask him next time you see him? (ie. is there any drain/fill plug on the transfer case)
Old 04-23-19, 11:33 AM
  #56
VisualEcho
VisualEcho's Avatar
Yes, of course, I just sent him a PM. He'll let me know.
Old 06-05-19, 02:40 PM
  #57
mopudding
mopudding's Avatar
is the Toyota tranny fluid synthetic?
Old 06-05-19, 05:28 PM
  #58
arentz07
drives cars
arentz07's Avatar
Received 3,505 Likes on 1,804 Posts
The Toyota Genuine ATF WS is semi-synthetic.
Old 06-07-19, 02:23 PM
  #59
WhatYaGot
WhatYaGot's Avatar
I had a 2006 IS350 I sold last year. I am the original owner. Never changed the transmission fluid and sold it with 238,000 miles. Shifted perfect!
Attached Thumbnails Lifetime Transmission Fluid What's your highest mileage-photo579.jpg
The following 3 users liked this post by WhatYaGot:
AtomicAWD (06-07-19), Jbreezie (09-16-19), swaangin (07-05-22)
Old 09-11-21, 04:14 PM
  #60
brsrafal
brsrafal's Avatar
Originally Posted by fxturbo
if you hadn't changed your transmission fluid what's your current highest mileage. Thanks
I had 06 camry orig fluid trans gave out at 320k prob cause i put lucas in it my buddy got lexus es 350 2002 over 300k orig fluid same with old ford van and another camry 1999 close to 300k orig fluid I have a new camry now 2019 sealed manual says do not touch my mechanic also says do not touch I'm wondering what I should do I'm hoping I get over 320k on this one . I believe my 06 started slipping after I used it to haul flooring that literally made the car low at around 280k ever since then i felt slippage so i made it to 320k.
Lukewarm (04-26-23)
Quick Reply: Lifetime Transmission Fluid What's your highest mileage
